Two Impulse & Impact Problems Need Help
In summary, the conversation discusses two problems related to impulse and force. The first problem involves Fernando Jose hitting a 0.05 kg golf ball with a speed of 65 km/s and finding the impulse of impact. The second problem discusses how automobile companies test the safety of cars by conducting crash tests and asks for the average force exerted on a 1000-kg car that stops in 0.09 seconds after hitting a cement wall at 15m/s. The key concept needed to solve both problems is the relationship between impulse and force, as described by Newton's second law.
yek_zzz
I need help in these two problems.
1. Fernando Jose hits a 0.05 kg golf ball, giving it a speed of 65 km/s. What impulse does he impact to the ball?
2. Automobile companies often test the safety of cars by putting them through crash test to observe the integrity of passenger's compartment. If a 1000-kg car is sent toward a cement wall with a speed of 15m/s and the impact stop the car in 0.09s, with what average force is it brought to a stop?
Hello!
Just fallow the link - impulse . You will find that impulse I = F*dt.
Newton's second law F = dp/dt (dp - is change in momentum p = mv) and dt is time in which momentum has changed.
Thats pretty much all you need to solve both problems.
FAQ: Two Impulse & Impact Problems Need Help
What are Two Impulse and Impact Problems?
Two Impulse and Impact Problems refer to a type of physics problem that involves calculating the change in momentum or velocity of objects after a collision or impulse.
What is the difference between Impulse and Impact?
Impulse refers to the force applied to an object over a period of time, while impact refers to the result of that force on the motion of the object.
How do you solve Two Impulse and Impact Problems?
To solve these types of problems, you will need to use the principles of conservation of momentum and energy, along with equations such as the impulse-momentum theorem and the kinetic energy equation.
What are some real-life examples of Two Impulse and Impact Problems?
Some real-life examples of these types of problems include car crashes, collisions between sports equipment, and the recoil of a gun after firing.
Why are Two Impulse and Impact Problems important to study?
These types of problems are important because they help us understand the behavior of objects during collisions and impacts, which can have practical applications in engineering, sports, and other fields.
