Two Kraus representations: How to check if they're the same TPCPM?
In summary, the Kraus representation theorem states that a map between two topological spaces is a trace-preserving completely positive map if and only if it can be written in an operator sum representation. This operator sum representation is not unique, and two representations of the same map may require a lot of time to work out.
Ameno
Hi
According to the Kraus representation theorem, a map [tex]\mathcal{E}: \text{End}(\mathcal{H}_A) \rightarrow \text{End}(\mathcal{H}_B)[/tex]
is a trace-preserving completely positive map if and only if it can be written in an operator sum representation [tex]\mathcal{E}: \rho \mapsto \sum_k A_k \rho A_k^\dagger[/tex] with [tex]\sum_k A_k^\dagger A_k = \text{Id}[/tex]
This operator sum representation is not unique. For example, [tex]\rho \mapsto (1-p)\rho + p \sigma_x \rho \sigma_x[/tex]
and [tex]\rho \mapsto (1-2p)\rho + 2pP_+\rho P_+ + 2pP_-\rho P_-[/tex]
where [tex]\sigma_x[/tex] is the Pauli x-operator and [tex]P_+, P_-[/tex] is the projector to the [tex]\sigma_z[/tex] eigenspace with eigenvalue +1, -1,
are two operator-sum representations of the same trace-preserving completely positive map.
My question is: Given two such operator-sum representations, what is the easiest way to find out whether the two representations give the same TPCPM or not?
with
This operator sum representation is not unique. [...]
Working out the image of a suitable spanning set of matrices, I guess.
Well, there are two ways I know how one can do this. One is what you have just written, the other one is to check if there is a unitary matrix s.t.
[tex]N_a = U_{\mu a}M_\mu[/tex]
where the N's and M's are the operators of two operator-sum representations.
I find that both require a lot of time to work out in practice, so I wonder if there is a more efficient way to do that.
You can also take the difference and simplify it to zero by expressing the operators involved in terms of a fixed set of generators for which you know all algebraic relations.
None of the methods is easy when the Kraus representations are arbitrary. But usually there is a preferred representation with a physical meaning, and when this is used consistentl;y, the question of equivalence doesn't arise.
FAQ: Two Kraus representations: How to check if they're the same TPCPM?
How do I know if two Kraus representations are the same TPCPM?
In order to determine if two Kraus representations are the same TPCPM (Trace Preserving Completely Positive Map), you need to check if they satisfy the following conditions:
  • They have the same number of Kraus operators.
  • Their Kraus operators are unitary equivalent.
  • Their Kraus operators have the same dimensions.
  • Their Kraus operators have the same rank.
  • Their Kraus operators have the same eigenvalues.
If all of these conditions are satisfied, then the two Kraus representations are the same TPCPM.
What is the significance of checking if two Kraus representations are the same TPCPM?
Checking if two Kraus representations are the same TPCPM is important in quantum information theory because it allows us to determine if two quantum channels are equivalent. This is crucial for tasks such as quantum error correction and quantum state discrimination.
What is a Kraus representation?
A Kraus representation is a mathematical representation of a quantum channel, which describes how a quantum state changes when it goes through the channel. It consists of a set of Kraus operators, which are matrices that act on the input state. The Kraus operators must satisfy certain conditions in order for the representation to be a valid quantum channel.
How do I check if two Kraus operators are unitary equivalent?
To check if two Kraus operators are unitary equivalent, you need to perform a unitary transformation on one of the operators and see if it becomes the same as the other operator. This can be done by finding a unitary matrix that transforms one operator into the other. If such a matrix exists, then the two operators are unitary equivalent.
Can two Kraus representations represent the same quantum channel but have different Kraus operators?
Yes, two Kraus representations can represent the same quantum channel but have different Kraus operators. This is because there are multiple ways to represent a quantum channel mathematically, and different sets of Kraus operators can result in the same channel. However, as long as the conditions for being the same TPCPM are satisfied, the two representations are equivalent and represent the same channel.
