Two liquids are inside of a U-tube, which
In summary, the two containers connected by a u-tube reach a steady equilibrium state where the oil with a density of ##900\frac{kg}{m^3}## exactly fills the left leg connected to the container with pressure ##p_1## and the other leg is filled with water. The pressure in the two containers can be determined using the equation ##p-p_0=Δp=\rho gh##, where the pressure of water is higher due to its higher density but the system is stabilized by an additional pressure at ##p_1##, resulting in ##p_1>p_2##.
PhyIsOhSoHard
158
Two containers are connected with a u-tube as shown above. An steady equilibrium state is reached where oil with a density of ##900\frac{kg}{m^3}## exactly fills the left leg connected to the container with pressure ##p_1## and the other other leg is filled with water. What can you say about the pressure in the two containers?
Correct answer: ##p_1>p_2##
##p_{H_2O}=1000\frac{kg}{m^3}\cdot gh##
##p_{oil}=900\frac{kg}{m^3}\cdot gh##
Since their height is the same, the only difference is the density.
However going by the two equations, water seems to have the bigger pressure but that isn't the correct answer. Apparently the oil has the bigger pressure?
Because the system is steady, the pressure in the middle must be equal - otherwise the system would moving.
Likes 1 person
I'm not sure I understand what you mean.
What would happen if the pressure of the oil in the middle point were higher or lower than the pressure of water there?
Likes 1 person
If the pressure is higher, it would push the water up, right?
So is it because the pressure of the two liquids are equal to each toerh at the bottom, there has to be an additional pressure at ##p_1## that cancels out the fact that the density (and thus pressure) of the oil is lower thus stabilizing the overall pressure at the bottom, hence ##p_1>p_2## right?
Right.
Likes 1 person
Related to Two liquids are inside of a U-tube, which
1. What is a U-tube and how does it work?
A U-tube is a glass or plastic tube bent into a U shape with two open ends. It is used for measuring the difference in height between two liquids. The liquids are poured into the tube until they reach the same level. This is due to the principle of communicating vessels, where the pressure at the same level in connected vessels is the same.
2. What are the two liquids typically used in a U-tube?
The two liquids commonly used in a U-tube are water and a denser liquid such as mercury or oil. Water is often used as it is easily available and has a known density, while the denser liquid helps to increase the sensitivity of the measurement.
3. How is the difference in height between the two liquids measured?
The difference in height between the two liquids is measured using a ruler or a graduated scale attached to the U-tube. The difference is typically measured in millimeters (mm) or centimeters (cm).
4. What factors can affect the accuracy of the measurement in a U-tube?
The accuracy of the measurement in a U-tube can be affected by factors such as the temperature of the liquids, the uniformity of the tube's diameter, and the precision of the measuring instrument. It is important to control these factors in order to obtain accurate results.
5. What are some applications of a U-tube in scientific experiments?
A U-tube is commonly used in experiments involving density and pressure. It can also be used to demonstrate the principle of communicating vessels and to measure the vapor pressure of a liquid. In addition, it is often used in chemistry labs for titration experiments to measure the volume of a liquid added to a solution.
