MHB *Two locomotives approach each other
  • Thread starter Thread starter karush
    Approach
Two locomotives traveling towards each other at 155 km/h are initially 8.5 km apart. The closing speed of the locomotives is 310 km/h, leading to a calculated time of approximately 1 minute and 39 seconds for them to meet. This is derived from the formula t = d/r, where d is the distance and r is the relative speed. Both methods of calculation confirm that the time to collision is about 99 seconds. The discussion emphasizes the importance of understanding relative speed in such scenarios.
karush
MHB
$\textsf{Two locomotives approach each other on parallel tracks.}\\$
$\textsf{Each has a speed of 155 km/h with respect to the ground.}\\ $
$\textsf{If they are initially 8.5 km apart}\\$
$\textsf{a. how long will it be before they reach each other?}\\$
\begin{align*}\displaystyle
t&=\frac{d}{r}\\
&=\frac{1}{2}\cdot\frac{8.5}{155}\\
&\approx0.0274 \, h \\
&\approx\color{red}{99 \, seconds}
\end{align*}
ok this looks very simple
so I'm sure I got it wrong
Mathematics news on Phys.org
closing speed is 310 km/hr
$t = \dfrac{d}{r} = \dfrac{8.5 \,km}{310 \,km/hr} \approx 1 \, min \, 39 \, sec$
Either argue, as skeeter does, that relative to one of the locomotives, the other has speed 155+ 155= 310 kph and has to go distance 8.5 km so will take time $\frac{8.5}{310}= 0.0274$ hours so 0.0274(60)= 1.6451 min= 1 min 39 seconds.
Or argue, as you apparently do, that, since the two trains have the same speed, 155 kph, and must cover half the distance, 8.5/2= 4.25 km, the time will be $\frac{4.25}{155}= 0.0274$ hours so 0.0274(60)= 1.6451 min= 1 min 39 seconds.
1 min 39 seconds is, of course, 60+ 39= 99 seconds as you say.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
