Two masses connected by a weighted rope pulled vertically
In summary: Thanks for your help!In summary, the tension at the top of the heavy rope is 120 N and at the middle of the rope it is 93.3 N.
Owen443
Two masses are connected by a heavy uniform rope (mass = 4 kg) and a upward force of 200N (Fa) is applied to the block on top; essentially the two masses and the rope are pulled up vertically. The mass on top (m1) weighs 6 kg, the mass on the bottom (m2) weighs 5 kg.
200 N
m1
| ← 4.0 kg rope
m2
Find the tension at the top and middle of the heavy rope.
Newton's Second Law, Fnet = ma
Force of gravity, mg
I found the acceleration of the whole system:
Fnet = ma
Fg + Fa = (6+4+5)(a)
a = 3.52 m/s^2 [upwards]
So for the top of the rope I figured that the tension should be supporting the weight of the the mass below it, Fg = mg = (4+5)(9.81), but I also know that since the system is accelerating upwards the tension should be greater, so:
Fnet = Force pulling the rope up + Force of gravity + Tension = (mass of rope + mass of m2)(g)
But I'm not really sure if the magnitude of the force pulling the rope up is 200N, and how I would find it if it isn't.
I have the same problem considering the tension in the middle
Here's my Fnet for that:
Fnet = Tension pulling it up + Tension pulling it down + Fg = (mass of half the rope + mass of m2)(a)
I think I have just a big lack of understanding of tension and I'm confused about what to do... any help /clarification about what path I should take would be greatly appreciated :)
Hi Owen443, Welcome to Physics Forums.
You've calculated the overall acceleration of the system properly, so that's good.
To determine the tension at the top of the rope, imagine that you were to replace the rope and lower box with an equivalent mass and draw a free body diagram for that mass. You know the acceleration of that mass so what can you say about the net force acting on that mass? What forces have to add up to that net force?
Thanks for the quick reply and welcome :)
If I consider the rope and the lower box as a single mass, I can find that the net force acting on it is Fnet = ma = (4+5)(3.52) = 31.68 N [upwards]. The problem I'm having is that I'm not 100% sure what forces have to add up to that net force. The way I see it now is that:
A. The upward force is the force applied by m1 (which I don't think is 200N), and the downward force is that of gravity
B. Upward force is force applied by m1 and the downward force is tension, but I know neither value for both, just that their vector sum is = 31.68 [upwards]
If I consider the midway point of the rope, I'd imagine that it'd be replaced with an equivalent mass (equal to half the mass of the rope and the mass of the lower box), but wouldn't the two forces acting on the FBD both be tension? I'm just having trouble identifying the exact forces acting on the points for each mass :(
You're almost there. You've identified two of the forces that you can find values for: The force due to gravity on the mass and the net force that accelerates it. The unknown tension at the top of the rope is the upward force applied. Three forces only one of which is unknown...
Ah thanks so much, I think I get it now :)
So if considering the top of the rope (where up is + and down is -)
##\vec F_{net} = \vec T + \vec F_g = m\vec a##
##\vec T - (4+5)|\vec g| = (4+5)(3.52)##
##\vec T = 120 N##
And if considering the middle of the rope:
##\vec T - (2+5)|\vec g| = (2+5)(3.52)##
##\vec T = 93.3 N##
Am I correct here? And again thank you so much, really appreciate it :)
##\vec T = 120 N##
##\vec T = 93.3 N##
That all looks right.
Related to Two masses connected by a weighted rope pulled vertically
What is the purpose of the weighted rope in this experiment?
The purpose of the weighted rope is to create a connection between the two masses and to add an additional variable to the experiment. The weight of the rope will affect the overall mass of the system and therefore, the acceleration and motion of the masses.
How does the weight of the rope affect the motion of the masses?
The weight of the rope will add to the overall mass of the system, causing a change in the acceleration and motion of the masses. The heavier the rope, the greater the mass and the slower the acceleration will be.
What factors can affect the motion of the masses in this experiment?
Aside from the weight of the rope, other factors that can affect the motion of the masses include the force applied to the system, the length of the rope, and the surface friction between the rope and the pulley. These factors can all impact the acceleration and motion of the masses.
What is the significance of pulling the rope vertically in this experiment?
Pulling the rope vertically allows for a simpler experiment with fewer variables. The motion of the masses will be in one direction and the force applied by the rope will be in a straight line, making it easier to measure and analyze the results.
How can this experiment be applied in real-world situations?
This experiment can be used to study the motion of objects connected by a rope, such as in a pulley system or a weightlifting scenario. It can also be used to understand how different variables, such as weight and force, affect the motion of the masses. This can have practical applications in fields such as engineering and physics.
