khannon5
- 24
Two masses are connected by a string that hangs over a frictionless pulley with mass 8kg, radius .25m, and moment of inertia .5mr^2. One mass lays on the ground and has mass 15kg. The other mass is 22.5 kg and is 2.75 m above the ground. Use conservation of energy to determine the speed of the 22.5 kg mass when it hits the ground
Ke final = pe initial
Ke=.5mv^2 + .5Iw^2
I found the pe of the 22.5 mass using pe=mgh. I made that equal the ke equation but I'm not sure whether to combine masses or what to use
