Two methods for finding spring constant k
In summary: Do you still think it is a quadratic?In summary, there are two methods for finding the spring constant, one using the force of gravity and the other using the decrease in potential energy. However, the second method is incorrect because it does not take into account the work done by all forces while lowering the mass onto the spring. When this work is included, the same result is obtained as the first method.
Jay_
183
Two methods for finding spring constant "k"
A box of mass 5 kg is made to rest on a vertical spring. The box compresses the spring by 10 cm, find the spring constant.
I felt this can be solved by two methods :
1. Force of gravity = Outward force of spring
2. The decrease in the potential energy = elastic potential energy stored in the spring.
The solution in my notes has the first method. So,
Solution by 1
F = mg
F = -kΔx ... Δx = 10 cm = 0.1 m
=> mg = kΔx
=> (5)(9.8) = k(0.1)
=> k = 490
Solution by 2
Initial potential energy of box = mgh
Potential energy at the compressed mg(h-0.1)
Elastic potential energy of the spring = (0.5)k(Δx)2
=> mgh - mgh(h-0.1) = (0.5)k(Δx)2
=> mg(0.1) = (0.5)k(Δx)2
=> (5)(9.8)(0.1) = (0.5)k(0.1)2
=> k = 980
So which of these methods is wrong and why?
The second method is wrong, because "2. The decrease in the potential energy = elastic potential energy stored in the spring." The sum of the gravitational potential energy and the elastic potential energy is the total potential energy. Now your statement is equivalent to "total potential energy is constant". There is no such law.
But even if you use conservation of energy (including the kinetic energy), the total energy of the system is conserved.
Since the kinetic energy is zero in both instances, the potential energies are conserved right?
Normally its
K1 + U1 = K2 + U2
Here, K1 and K2 are zero. Leaving
U1 = U2.
Suppose you are initially holding the box at rest at the top of the spring with the spring uncompressed. You then lower the box onto the spring until the spring compresses to the point where you can let go of the box and the spring supports the box at rest.
How many forces act on the box while it is being lowered? Does your energy equation account for the work done by all of these forces?
Nope. The exercise says "is made to rest on.." If you just let go of the box with the spring extended, it will oscillate up and down around the 10 cm.
At the lowest point Ekin = 0 again and the compression is 20 cm. All potential energy from gravity has been converted into spring compression energy.
At the highest point Ekin = 0 and all the initial energy is potential energy from gravity again.
At the 10 cm point only half is spring compression, the other half is kinetic energy.
[edit]T was faster - again!
That is true.
Others have commented on this, and I will from a slightly different perspective. Write the full equation for conservation of energy: ##K_1 + U_1 = K_2 + U_2##. Now, as you say, assume that ##K_1 = K_2 = 0##. This obviously means ##U_1 = U_2##. This is a quadratic equation, so it will have two roots. Does that really mean that the mass-spring system has two equilibrium points? Or does that mean something else?
voko said:
That is true.
How is it a quadratic? We know the value of x. The unknown variable is 'k'
Chestermiller said:
Hi Jay,
Please see the following thread which is contemporary with your thread:
https://www.physicsforums.com/showthread.php?t=741582
Chet
Hi Chestermiller,
The post by nasu in that link says that when you "place it gently" the energy of the of the weight-spring system is not conserved. What gives? I read the other posts but I thought in such a system energy is conserved at every point in time - only with translation from one form to another.
Jay_ said:
Hi Chestermiller,
To get the mass to the equilibrium position, you have to lower the weight gradually so it doesn't overshoot. If you just let it go at the top, it will develop kinetic energy and overshoot to twice the equilibrium compression. Then it will bounce back up.
To lower it gradually, there is another force that has to be taken into account, and this force adds a work term to your energy balance. This is the force that you have to be applying as the mass descends gradually to its equilibrium position. As the mass descends, you are reducing the force you are exerting as the spring assumes more of the load. When the mass gets to its equilibrium position, the force you need to be applying will decrease to zero. At the time that the mass reaches the equilibrium position, the work you will have done will be -mgx. This is the missing energy in your energy balance. If you include this, you will get the same answer as the force equilibrium result.
Chet
Likes 1 person
Thank you Chestermiller! That clears it all. :-)
Interpret that as if k were known, and x were unknown.
Related to Two methods for finding spring constant k
What is the definition of spring constant k?
The spring constant, denoted as k, is a measure of the stiffness of a spring. It represents the amount of force required to stretch or compress a spring by a certain distance.
How is spring constant k calculated?
There are two methods for calculating spring constant k: Hooke's Law and the slope of the force vs. displacement graph. Hooke's Law states that k = F/x, where F is the applied force and x is the resulting displacement. The slope of the force vs. displacement graph is also equal to k.
What is Hooke's Law and how does it relate to spring constant k?
Hooke's Law is a principle that describes the relationship between the force applied to a spring and the displacement of the spring. It states that the force applied is directly proportional to the displacement of the spring, with the constant of proportionality being the spring constant k.
Can spring constant k change?
Yes, spring constant k can change depending on the material and design of the spring. It can also be affected by external factors such as temperature and wear and tear.
What units is spring constant k measured in?
Spring constant k is typically measured in units of Newtons per meter (N/m) in the metric system or pounds per inch (lb/in) in the imperial system. However, other units such as dynes per centimeter (dyn/cm) or pounds per foot (lb/ft) may also be used.
