MHB Two normal independent random variables
The discussion focuses on demonstrating that the sum and difference of two independent normal random variables, X and Y, are independent without using Jacobian transformation. The joint moment generating functions (MGFs) of X+Y and X-Y are analyzed, revealing issues with earlier calculations, particularly regarding the variance of X-Y. A suggestion is made to approach the problem using covariance, noting that for normal variables, zero covariance implies independence. The corrected joint MGF for X+Y is confirmed to be e^(2μt + σ²t²). The conversation emphasizes the importance of accurate MGF calculations and the relationship between covariance and independence in normal distributions.
WMDhamnekar
MHB
Let X and Y be independent normal random variables each having parameters $\mu$ and $\sigma^2$. I want to show that X+Y is independet of X-Y without using Jacobian transformation.
Hint given by author:- Find their joint moment generating functions.
Answer: Now Joint MGf of $X+Y={e^{\mu}}^{2t}+\sigma^2t^2$ and of $X-Y=1$. So, joint MGF of $X+Y+X-Y$ is $e^{2\mu t}+ \sigma^2 t^2$. This indicates they are independent. Is their any other method in advanced calculus?
There are some problems with your use of MGFs. The sigma should be inside the exponential function for the $X+Y$ though you seem to have done this for $X-Y$. But that has another issue:: X-Y is zero mean but still normal, yet a zero mean random variable has zero variance iff it is identically zero (almost surely). Your MGF implies zero variance yet, I can use coin tossing to show there is at least 25% chance of $X-Y \gt 0$ and at least 25% chance $X-Y \lt 0$ which is a contradiction. (It's actually 50:50, but lower bounding this at 25% each is a much easier argument and gets the same desired contradiction.)
Why not consider tackling this head on by looking at covariance?
$A: = X+Y$
$B: = X-Y$
where $A$ and $B$ are normal random variables.
In general independence implies zero covariance but not the other way around. Except zero covariance does imply independence for normal random variables.
$\text{Cov}(A,B) $
$= \text{Cov}(X+Y, X-Y) = E\big[(X+Y)(X-Y)\big] - E\big[(X+Y)\big]E\big[(X-Y)\big] = E\big[X^2 -Y^2\big] - E\big[X+Y\big]E\big[X-Y\big]$
$ = E\big[X^2\big] -E\big[Y^2\big] - E\big[X+Y\big]\cdot 0 = 0$
(The fact that X and Y have same first moment and variance implies second moment is the same and that
$E\big[X - Y\big] = E\big[X\big] - E\big[Y\big] = 0$.)
$A: = X+Y$
$B: = X-Y$
$\text{Cov}(A,B) $
You are correct. It is a typo. The joint MGF of X+Y=$e^{2\mu t+ \sigma^2 t^2}.$ The joint MGF of X+Y+X-Y=$e^{2\mu t + \sigma^2 t^2}$
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
