Two packages stacked on one another
  • Thread starter hamzaarfeen
In summary, the delivery person is trying to reach his top speed while keeping a poorly packaged vase from sliding off the top of a stack of two packages in the back of a delivery van. The upper package has a mass of 4.0 kg and the lower package is fixed to the floor of the van with a mass of 6.5 kg. The coefficient of static friction between the two packages is 0.211. To solve for the minimum amount of time it takes for the delivery person to reach his top speed, you must use the equations f=ma and F_{fr top} = (m_{top})(a) = (u_s)(F_{N top
hamzaarfeen
A delivery van has two packages left that are stacked one on top of another. The upper packages
has a mass of 4.0 kg and is a poorly packaged glass vase, while the lower package has a mass
6.5 kg. The coefficient of static friction between the two packages is 0.211 and the lower box is
fixed to the floor of the van. Since the delivery person is late, he has been accelerating quickly
whenever he has stopped and started (at lights, stop sign etc.), however he never exceeds the
town's speed limit of 60 km/h. What is the minimum amount of time it takes for him to reach
his top speed while still keeping the vase from breaking (sliding off the top box).
friction= coefficient x contact force
fnet=ma
friction = 0.211x 4kg x 9.81
= 8.24N
what do i do next?
a hint: for the 4kg box not to slide off of the 6.5kg box it must have the same acceleration as the 6.5kg box, this acceleration is caused by the static friction between the two boxes
so how can i solve it? if i make two equations, then one can be made for the upper box using f=ma, but what about the other equation?
find the acceleration using the hint, and then using this acceleration find the time to reach 60 km/h...I hope I'm not giving away too much but to find the acceleration know that:
[itex] F_{fr top} = (m_{top})(a) = (u_s)(F_{N top}) [/itex]
To find the minimum amount of time it takes for the delivery person to reach their top speed while keeping the vase from sliding off, we need to use Newton's second law, fnet=ma. The net force acting on the stacked packages is the force of friction between them, which we calculated to be 8.24N. This force is also equal to the mass of the packages (10.5kg) multiplied by their acceleration. So, we can rearrange the equation to solve for acceleration: a = fnet/m = 8.24N/10.5kg = 0.785 m/s^2.
Next, we can use the equation v = u + at, where v is the final velocity, u is the initial velocity (which we can assume to be 0 since the van starts from rest), a is acceleration, and t is time. We know that the town's speed limit is 60 km/h, which is equivalent to 16.67 m/s. So, we can plug in these values and solve for t: t = (16.67 m/s)/0.785 m/s^2 = 21.25 seconds. This is the minimum amount of time it takes for the delivery person to reach their top speed while keeping the vase from sliding off.
FAQ: Two packages stacked on one another
How does the weight of the top package affect the stability of the bottom package?
The weight of the top package can greatly impact the stability of the bottom package. If the top package is significantly heavier than the bottom package, it can cause the bottom package to become unbalanced and potentially topple over.
Can stacking two packages on top of each other cause damage to the contents inside?
Yes, stacking two packages on top of each other can potentially cause damage to the contents inside. If the packages are not sturdy enough or if they are stacked too high, the pressure from the weight of the top package can crush the items inside the bottom package.
Is it safe to stack packages of different sizes on top of each other?
It is generally not recommended to stack packages of different sizes on top of each other, as this can create an unstable and potentially dangerous situation. It is best to stack packages of similar sizes and weights for optimal stability.
How high can I safely stack packages on top of each other?
The maximum height for stacking packages on top of each other depends on the weight and stability of the packages. As a general rule, it is recommended to not stack packages higher than your waist level to prevent potential accidents.
Are there any precautions I should take when stacking two packages on top of each other?
Yes, there are some precautions to keep in mind when stacking two packages on top of each other. Make sure both packages are secure and not damaged. Use caution when stacking heavy or fragile items. And always be mindful of the weight and stability of the packages to prevent any accidents or damage.
