Two Parallel Conducting Plates with moving charge
In summary, using the conservation of energy equation and the given values of potential difference and charge, we can calculate the speed at which the pellet will reach the other plate, which is 4.14 × 10^3 m/s.
arl146
343
Two parallel conducting plates that are in deep space are brought to a potential difference of 3500 V, and a small pellet of mass 6.95 mg carrying a charge of 6.70 × 10-7 C accelerates from rest from the positive plate. With what speed will it reach the other plate?
I'm thinking conservation of energy.
Ki+Ui=Kf+Uf
I know that Ki ends up being 0 so it just becomes Ui=Kf+Uf. I have no idea what the potential energy would be since I don't have a distance.?
Hello! You are correct in thinking that conservation of energy will be useful in solving this problem. The potential energy in this case will be the potential difference between the two plates, which is given as 3500 V. The distance between the plates is not needed in this case since the electric potential energy only depends on the potential difference and the charge of the object.
So, using the conservation of energy equation, we can write:
(1/2)mv^2 + qV = 0 + 0
Solving for v, we get:
v = √(2qV/m)
Plugging in the values given in the problem, we get:
v = √(2(6.70 × 10^-7)(3500)/6.95 × 10^-6)
v = 4.14 × 10^3 m/s
Therefore, the pellet will reach the other plate with a speed of 4.14 × 10^3 m/s.
I hope this helps! Let me know if you have any further questions.
FAQ: Two Parallel Conducting Plates with moving charge
1. What is the concept of "Two Parallel Conducting Plates with moving charge"?
The concept refers to a basic setup in electromagnetism where two parallel plates made of conducting material are placed close to each other. A charge is then placed on one of the plates, causing it to move, which creates an electric field between the plates.
2. How does the movement of the charge affect the electric field between the plates?
The movement of the charge on one plate creates an electric field that extends between the two plates. This electric field becomes stronger as the charge moves faster, and weaker as the charge slows down or stops.
3. What is the significance of the conducting material in the plates?
The conducting material allows for the movement of charges between the two plates. This movement of charges creates an electric field, which is essential for many applications in electromagnetism, such as capacitors and parallel plate filters.
4. How does the distance between the plates affect the electric field?
The distance between the plates directly affects the strength of the electric field. As the distance between the plates decreases, the electric field becomes stronger, and as the distance increases, the electric field becomes weaker.
5. What is the mathematical expression for the electric field between the plates?
The electric field between the two parallel plates is given by the equation E = Q/εA, where E is the electric field, Q is the charge on the plate, ε is the permittivity of the medium between the plates, and A is the area of the plates.
