Two-particle fermionic basis states
In summary, the conversation discusses the basis states for a two-particle system of fermions, specifically whether they are simply the product of single-particle states or some obscure linear combination. The concept of tensor product spaces and how they relate to the basis states is explained, and the mathematical theorem that supports the use of product states as a basis is mentioned. The idea of using a z-axis to measure spin is also discussed.
Niles
1,866
Hi guys
Say we are looking at a two-particle system consisting of two electrons (fermions). In my book it says that the basis states are given by
[tex]
\left| {\psi _{\alpha ,i} (r_m )} \right\rangle \left| {\psi _{\beta ,j} (r_n )} \right\rangle
[/tex]
where rm and rn denote the two particles. My question is, how do we know that the basis states are merely the product of the single-particle states, and not some obscure linear combination?
Try f1(rm)f2(rn)-f1(rn)f2(rm)
That was not really my question. In my book they specifically state that single particle states are given by
[itex]
[/itex]. My question is why.
[itex]
A linear combination of two states S1, S2 means it's either one or the other (with probabilities
given by the weightings of the two terms in the superposition). I.e., it's a state of 1
particle which could either be in state S1 or S2. But here we want a state representing a
composite system that's definitely got two particles...
The product expression corresponds to a state in a tensor product of two single-particle
Hilbert spaces. Check out Wiki for the mathematical detail on tensor product spaces.
We use them in QM because the tensor product of two Hilbert spaces is itself a Hilbert
space. Ballentine's text covers this topic fairly well, iirc.
The intuitive idea is simple: every matrix [tex]a(i,j)[/tex] can be represented as a linear combination of simple matrices [tex]a(i)a(j)^T[/tex] where [tex]a(i)[/tex] is a vector that has i-th component 1 and all other zero. Every matrix, thought as a square table is a linear combination of matrices with one entry =1 and all other entries =0.
That's the idea. Then come tensor products and mathematical theorems stating that every function f(x,y) of two variables can be approximated by sums of products of functions of one variable.
This comes from the choice of a z axis upon which the spin of an electron is measured. We have a up state and a down state relative to this axis. these states form a basis in a 2 dimensional space.
For 2 electrons we use the tensor product of two such basis:
(I note it ¤)
up ¤ up, up ¤ down, down ¤ up, down ¤ down
We can choose another basis:
(up¤down - down¤up)/sqrt(2) , up¤up, (up¤down + down¤up)/sqrt(2) , down¤down
The 4 dimensional space is the sum of a singlet (maximum spin = 0) and a triplet (maximum spin = 1)
Adding to the above: of course you could take "obscure linear combinations" as your basis. But what for if a mathematical theorem states that "(tensor) products of the basis vectors form a basis for the (tensor) product space"? (In fact for indistinguishable fermions you should antisymmetrize the products as mentioned by naima.)
Does such a theorem exist? If yes, can I ask what it is called (I'll google it afterwards)?
FAQ: Two-particle fermionic basis states
1. What are two-particle fermionic basis states?
Two-particle fermionic basis states are quantum states describing the behavior of two identical fermions, such as electrons, in a system. They are used in quantum mechanics to describe the possible energy levels and spatial configurations of the two particles.
2. How are two-particle fermionic basis states different from bosonic states?
The key difference between fermions and bosons is their spin, with fermions having half-integer spin and bosons having integer spin. This results in different mathematical rules for describing their behavior, including the use of different basis states.
3. Can two-particle fermionic basis states be entangled?
Yes, two-particle fermionic basis states can be entangled, meaning that the behavior of one particle is linked to the behavior of the other, even when they are physically separated. This is an important concept in quantum information and computing.
4. How are two-particle fermionic basis states used in real-world applications?
Two-particle fermionic basis states have various applications in fields such as quantum chemistry, where they are used to describe the electronic structure of molecules. They are also used in quantum computing algorithms, such as the quantum Fourier transform.
5. Are there any limitations to the use of two-particle fermionic basis states?
One limitation of using two-particle fermionic basis states is that they can only accurately describe systems with two identical fermions. For systems with more particles or different types of particles, more complex basis states are needed. Additionally, the calculations involving these states can become exponentially complex for larger systems, making them challenging to use in certain applications.
