Two Particles' Spin Hamiltonian Analysis?
In summary, the conversation discusses using bra-ket notation and quantum mechanics to find the hamiltonian's eigenvalues and eigenstates. The hamiltonian is given by H=(S_{1z}+S_{2z})+S_{1x}S_{2x} and the states basis is given by |++\rangle, |+-\rangle, |-+\rangle, |--\rangle. Applying the hamiltonian to each basis ket gives eigenvalues of \hbar/2, 0, 0, and -\hbar/2 respectively. The conversation also addresses a question about considering |−+⟩.|+−⟩=0, which is not correct.
cacofolius
30
Hi, I'm trying to familiarize with the bra-ket notation and quantum mechanics. I have to find the hamiltonian's eigenvalues and eigenstates.
##H=(S_{1z}+S_{2z})+S_{1x}S_{2x}##
##S_{z} \vert+\rangle =\hbar/2\vert+\rangle##
##S_{z}\vert-\rangle =-\hbar/2\vert-\rangle ##
##S_{x} \vert+\rangle =\hbar/2\vert-\rangle##
##S_{x} \vert-\rangle =\hbar/2\vert+\rangle, ##
The states basis is ##\vert++\rangle,\vert+-\rangle, \vert-+\rangle, \vert--\rangle ##
3. The Attempt at a Solution
What I did was apply the hamiltonian to each basis ket
##H\vert++\rangle =(S_{1z}+S_{2z})\vert++\rangle + S_{1x}S_{2x}\vert++\rangle
= \hbar/2\vert++\rangle + \hbar/2\vert++\rangle + \hbar/2\vert-+\rangle . \hbar/2\vert+-\rangle = \hbar/2\vert++\rangle##
##H\vert+-\rangle = 0##
##H\vert-+\rangle = 0##
##H\vert--\rangle = -\hbar/2\vert--\rangle##
My questions:
1) Is it right to consider ##\vert-+\rangle . \vert+-\rangle = 0##, (since they're orthogonal states)? Because they're both ket vectors (unlike the more familiar ##<a|b>##).
2) In that case, is the basis also the hamiltonian's, with eigenvalues ##\hbar/2, -\hbar/2, 0## (degenerate) ?
Post this in the advanced physics homework section
cacofolius said:
Is it right to consider |−+⟩.|+−⟩=0\vert-+\rangle . \vert+-\rangle = 0,
No, that's not right. Moreover, ## S_{1x}S_{2x}|++\rangle \neq \hbar/2\vert-+\rangle . \hbar/2\vert+-\rangle ##. It's like you are producing four electrons out of two electrons. The operator of the first particle only acts on the first entry of the ket and that of the second particle acts on the second entry.
Related to Two Particles' Spin Hamiltonian Analysis?
What is a "spin Hamiltonian"?
A spin Hamiltonian is a mathematical description of the energy levels and interactions between two particles with spin, such as electrons or atomic nuclei. It takes into account the spin states of the particles and the external magnetic field they are in.
What are the components of a spin Hamiltonian?
A spin Hamiltonian typically includes terms for the spin operators of each particle, as well as terms for their interaction with each other and with an external magnetic field. It may also include terms for other interactions, such as spin-orbit coupling.
What is the significance of the spin Hamiltonian in quantum mechanics?
The spin Hamiltonian is a key tool in understanding the behavior of particles with spin in quantum mechanics. It allows us to calculate the energy levels and how they change in response to external magnetic fields, as well as how particles with different spins interact with each other.
How is the spin Hamiltonian different from other types of Hamiltonians?
The spin Hamiltonian is specifically tailored to describe the behavior of particles with spin. Other types of Hamiltonians may be used to describe different types of particles or systems, such as those with rotational or vibrational degrees of freedom.
Can the spin Hamiltonian be solved exactly?
In most cases, the spin Hamiltonian cannot be solved exactly. However, there are some special cases where exact solutions are possible, such as when the particles have only two possible spin states or when they are in a uniform magnetic field. In most cases, numerical methods or approximations are used to solve the spin Hamiltonian.
