CAF123
- 88
Identical pendulums of length ##L## are suspended from the ceiling a distance ##a## apart. Each of the pendulums carries a particle of mass ##m##. The two particles are connected horizontally by a spring of natural length ##a##. Consider only motion in the plane formed by the pendulums and the spring and assume that the displacments of the pendulums from the vertical, ##x_1, x_2## are small. (i.e the angles of deflection are small)
1)Express the total energy as a sum of kinetic and potential terms using the variables ##x_1, x_2## and their derivatives (NB: Include the potential energy stored in a spring and gravity)
2)Bring the energy into the form $$E = \frac{1}{2}\underline{\dot{x}^T} M \underline{\dot{x}} + \frac{1}{2}\underline{\dot{x}^T} K \underline{\dot{x}},$$ M, K matrices.
1) I dealt with each pendulum separately. They are joined only via the spring and so this will come across in the changing elastic potential energy stored in the spring:
Define coordinates where the pendulum is attached to the ceiling with positive x to left and positive y downwards. Let ##L = l##Then for this pendulum:
$$V_1 = -mgy_1 = -mg(\sqrt{l^2 - x_1^2}),\,\,\,T_1 = \frac{m}{2}\left[\frac{\dot{x_1}^2 l^2}{l^2 - x_1^2}\right]$$
For the other pendulum, again put x +ve to right and y postive down and origin at ceiling: Then $$V_2 = =mg\sqrt{l^2 - x_2^2}\,\,T_2 = \frac{m}{2}\left[\frac{\dot{x_2^2} l^2}{l^2 - x_2^2}\right]$$
For the spring, I think the expression will change depending on whether the springs move in phase or not. If one is displaced to the right by x1 and the other to the left by x2 then ##U_S = \frac{1}{2}k(x_1 - x_2 - a)^2##
I can then add all these together. I haven't used the fact that the displacements are small. I thought about neglecting sqaured terms etc.. but then all the kinetic terms would drop out. I am not sure about my expression for ##U_S## either since I can come up with another expression depending on the relative motion of the two pendula.
Many thanks.
