Coffee_
- 259
- 2
QUESTION 1. I have asked this question here a while before but it seems that I have still not gotten it. My apologies to the previous answerers of this one, I guess it's just me being slow.
We defined the electromotive force ##\epsilon## for a charge that moves along some path while some force ##\vec{F}## of electromagnetic origin acts upon it C as: ##\int_C \frac{\vec{F}}{q}\vec{dl}##
The electrostatic definition of a potential difference between point A and point B for any path C going from A to B is given by ##\Delta{V}=-\int_C \vec{E} \vec{dl}##
It is easy to see that in purely the electrostatic case for a path C from point A to point B ##\Delta{V}=-\epsilon## Is there a way to do an exactly the same formal reasoning to find this exact same result for electrodynamics cases where the magnetic force is involved? Because right now I have the feeling that in electrodynamics the result is going to be ##\Delta{V}=\epsilon## without the minus sign.
QUESTION 2. This question is about a step in a derivation I'm confused about. The point of the derivation is to show that the energy density of a created magnetic field goes with ##B^{2}##. Consider a single loop with a current ##I## running through it. The potential energy stored in the total flux through the surface is equal to ##U=\frac{I \Phi}{2}##
And so we can associate a small potential energy with a small piece of flux through the loop as ##dU=\frac{I d\Phi}{2}## Now let's take the special geometric set of field lines that contain the same amount of field lines through space. I think they are called stream surfaces? Anyway the point is that with each ##d\Phi## through the surface we can associate such a stream surface through which the flux is constant.
This gives ##dU=\frac{I \vec{B} \vec{dS}}{2}##. Where ##\vec{B}## and ##\vec{dS}## can be taken anywhere on the stream surface as long as they are both corresponding to each other. This is because the amount of field lines and thus the flux through a stream surface is constant.
Now we use Maxwell's magnetic circulation law in integral form along one field line in this stream surface. This means that ##\oint_C B dl = \mu_{0} I## where I already use that B and dl are parallel.
So including this into our expression we find: ##dU= \frac{1}{2\mu_{0}} \oint_C B^{2} dl dS(x,y,z)## What basically happens here is that one B field is being integrated over. The other expression has the B field for the flux which can be any B value along the stream surface as long as it corresponds to a correct ##dS## of the stream surface. If I take the value for the latter B field equal to the value of the B field I'm taking a line integral over dS would become a function along the line integral. I get everything until here.
The next step is the proof saying that if we integrate over all those ##dU## we find ##dU= \frac{1}{2\mu_{0}} \iiint_V B^{2} dV## and thus the value in the integral represents the energy density.
I don't get the math or formal reasoning behind the last step, can someone explain or elaborate.
Thanks a lot.
Thanks a lot.
