Two questions about Newton's law
In summary: I realized that I was missing a very basic step: setting up a force equation. I had all the numbers, but I never set up a force equation. Thank you so much for reminding me of a very fundamental step.In summary, the fisherman yanks a fish out of the water with an acceleration of 4.5 m/s^2 using very light fishing line with a "test" value of 22N. The fisherman loses the fish as the line snaps. Using a force equation, the mass of the fish can be determined to be greater than 1.51 kg.
cyspope
27
9. A fisherman yanks a fish out of the water with an acceleration of 4.5 m/s^2 using very light fishing line that has a "test" value of 22N. The fisherman unfortunately loses the fish as the line snaps. What can you say about the mass of the fish?
A. m > 1.5 kg
15. A 75 kg theif wants to escape from a third story jail window. Unfortunately, makeshift rope made of sheets tied together can support a mass of only 58 kg. How might the theif use this "rope" to escape? Give quantitative answer.
A. a (downward) >_ 2.2 m/s^2
9. F = ma
15. F = mg
9. F = ma → m = F / a = 22 / 4.5 = 4.9 kg
This is what I thought. However, the answer is 1.5 kg. I don't understand what I did wrong.
15. I don't think the thief can get out of the jail. Howevery, there is the "ununderstandable" answer.
A. m > 1.5 kg
9. F = ma
15. F = mg
Your first solution seems right to me. Maybe it was a miscalculation by your teacher, typo in the solutions, or it hinges on what the definition of a "test value" is for fishing equipment.
For the second problem, I'd say to fold the rope, making each part of the fold carry half the weight.
You forgot to account for gravity.
I also don't understand what answer the teacher is looking for. Maybe using two ropes in parallel?
The force on the rope is less than the weight of the man if he slides down with a certain acceleration.
He can do it by grabbing the rope at his breast and letting his body fall, and grabbing the rope with the other hand and so on. You can try it.
The forces acting on the man are gravity and the tension of the rope. This tension can not exceed 58g.
If the downward acceleration of the man is a, its mass is m,
mg-T=ma, 75a>=75g-58g, a>=g(1-58/75)=2.2 m/s^2.
I still don't understand what to do for number 9. I drew Free Body Diagram, and I realized that there are three kinds of forces: mg(down), ma(up), and T(up; along with ma(up)). I found those three forces, but I don't know what to do next.
for problem(9) .. you got the answer and you want the explanation ..
first you did great when you decided to draw the free body diagram, but why didnt you just substitute the numbers you have?
its just simply applying F(net) = ma >> T-mg = ma >> 22 - 10*m = 4.5m >> 22 = 14.5m
which leads you to m = 1.51 , then the mass of the fish should be greater than this value in order for the fishing line to snap .. :)
Thank you so much~!
FAQ: Two questions about Newton's law
What is Newton's First Law of Motion?
Newton's First Law of Motion, also known as the Law of Inertia, states that an object at rest will remain at rest and an object in motion will remain in motion at a constant velocity unless acted upon by an external force.
What is Newton's Second Law of Motion?
Newton's Second Law of Motion states that the acceleration of an object is directly proportional to the net force acting on it and inversely proportional to its mass. In other words, the greater the force applied to an object, the greater its resulting acceleration will be, and the larger the mass of an object, the smaller its resulting acceleration will be.
What is the formula for Newton's Second Law?
The formula for Newton's Second Law is F = ma, where F is the net force applied to an object, m is the mass of the object, and a is the resulting acceleration. This formula can also be rearranged to solve for any of the variables, such as a = F/m or m = F/a.
How is Newton's Second Law related to the concept of inertia?
Newton's Second Law is directly related to the concept of inertia, as it states that the acceleration of an object is dependent on its mass. Inertia is the tendency of an object to resist changes in its state of motion, and an object with a larger mass will have a greater resistance to changes in its motion compared to an object with a smaller mass.
What are some real-life examples of Newton's Second Law?
Examples of Newton's Second Law can be seen in everyday life, such as when you push a shopping cart and it starts moving with a certain acceleration based on the force you apply to it and its mass. Another example is when a pitcher throws a baseball, the greater the force they apply to the ball, the faster it will accelerate and the further it will travel. Similarly, a heavier object will require more force to accelerate it compared to a lighter object.
