fox26
- 40
- 2
Arnold Neumaier,
I have 2 elementary questions about your article “The Physics of Virtual
Particles”.
1. In the paragraph headed “States.” on p. 4, of 13, you talk about states of a
physical system, with a mixed state specified by a Hermitian operator ρ of trace
1 acting on the Hilbert space of the system which contains the system’s pure
state vectors. You say that this also covers the pure case with ρ = ψψ*. Do the
symbols on the right-hand side of this equation indicate the product, in the
standard product of functions sense, of ψ with its complex conjugate? If so, for a
system consisting of just one particle, ρ is a function of the arguments r and t of
ψ whose value at each (r,t) is the probability density of finding the particle at the
point r at time t in whatever space the argument r of ψ is, e.g., position space or
momentum space. This ρ doesn’t sound like a Hermitian operator of trace 1, and
doesn’t even specify a state completely; for example, if the value of ρ is the
position probability density, ρ doesn’t determine the momentum probability
density, and vice-versa. Was this just a case of your using “ρ” for two different
things, that is, with two different meanings?
2. In the paragraph headed “Stable and unstable particles.” on p. 5, you say
that stable particles, according to the QFT formalism, must be on-shell, meaning
that their momentum p is related to the real rest mass mm (sic) (doubling due to
typo?) by the relation p2 = m2 (in units where c = 1). You clearly were not talking
just about particles that move (in vacuum) only at speed c (= 1 in your units). In
relativistic mechanics, p2 = m2v2, where m is the relativistic (moving) mass, not
the rest mass, and v2 = 1 (in your units) only for particles moving at speed c. The
“v2" was omitted in that equation in 3 later paragraphs, in the first of which, for
complex p and m, after the equation “p2 = m2", you have “and v = p/m real",
implying p2 = m2v2. Is the omission of all those “v2" ‘s due to a peculiarity of QFT,
to the fact that you were thinking just of particles moving with speed c (= 1) when
you were writing this but neglected to specify that limitation, or is it just a strange
repeated typo or other similar error--or something else?
--fox26
Particles”.
--fox26
