Two questions related to "classical problem" of the image method
In summary, the classical problem of the image method involves an infinite conducting and grounded (V=0) plate on the xy plane with a charge ##q## above it on the #z# axis. By solving the boundary value problem for the region ##z>0##, we can find the potential, ##V##. The surface charge on the plane, ##\sigma##, is given by ##\sigma = -\epsilon_o \frac{\partial V}{\partial n} \big|_{z=0}##, which may seem counterintuitive since the derivative, ##\frac{\partial V}{\partial n}##, is discontinuous at ##z=0##. However, this discontinuity is crucial
davidbenari
466
The classical problem of the image method is:
An infinite conducting and grounded (V=0) plate is on the xy plane. A charge ##q## is above it (we can think that it lies on the #z# axis). Knowing that ##V \to 0## as you move far away from the charge and that ##V=0## on the plane find the potential for the region ##z>0##.
Okay and my questions are:
(1) After finding ##V## why would ##\sigma = -\epsilon_o \frac{\partial V}{\partial n} \big|_{z=0}## be the surface charge on the plane?
My objection to this is that the derivative ##\frac{\partial V}{\partial n}## is discontinuous at ##z=0##. It could either be ##0## or ##\sigma##. What makes it not vanish? In other words, why, if there is a discontinuity, does only the value we want pop up?
(2) How can we be sure the electric field below the xy plane is ##0##?
I think the typical answer is that fields can't penetrate conductors. Why is this the case? I do accept that ##E=0# inside a 3D conductor but this is a 2D conductor, and for that matter it seems to me that the statement "Fields can't penetrate conductors" is more general. Is it true? If not, then why is the field below the xy plane equal to zero?
EDIT
Mhmm, Three questions, sorry.
(3) The energy can be calculated considering how much work it takes to bring the charge from infinity to a distance ##d## above the plate. Why is this so?
My objection to this is that the calculation of energies for a continuous charge distribution and a collection of point charges if fundamentally different.
The energy for a continuous charge distribution is positive definite since it is related to the integral of ##E^2## while the energy of a collection of particles can be negative. So it seems to me that we have to ways of talking about the energy here: Either we integrate the field over all space, or we just consider the work it takes to bring in charge ##q##.
Let ##\Omega## be the region ##z>0##. We want to solve the following boundary value problem(s):
$$\Delta \Phi_1 = - \rho \quad \text{ in } \Omega$$
$$\Phi_1(z=0)=0$$
where ##\rho=-q \delta(z-d)##
And let ##\Omega^{'}## be the region ##z<0##
$$\Delta \Phi_2 = 0 \quad \text{ in } \Omega^{'}$$
$$\Phi_2(z=0)=0$$
Where ## \vec E = -\nabla \Phi##
For the solution in all ## \mathbb R^{3}## we must patch together the solutions for ##\Phi## in ##\Omega## and ##\Omega^{'}##
In ##\Omega^{'}## the solution is clearly ##\Phi_2 \equiv 0 \Rightarrow \vec E_2 \equiv 0##, and we can understand that as if we have an infinite conductor sitting at ##z<0##
Now, we can compute $$\sigma= \epsilon_0(\vec E_2 - \vec E_1) . \hat n \Rightarrow \sigma=- \epsilon_0 \frac{\partial \Phi}{\partial n}$$
But ##\frac{\partial \Phi}{\partial n}## is discontinuous at the the plate isn't it? So it doesn't make much sense to evaluate it.
No, the electric field is discontinuous at ##z=0##, but the potential is not.
The solution (in cylindrical coordinates) is $$ \Phi_1(r,\phi, z) = \frac{1}{4 \pi \epsilon_0 } \bigg ( \frac{q}{\sqrt{r^2 + (z-d)^2}} - \frac{q}{\sqrt{r^2 + (z+d)^2}} \bigg ) \quad \quad z>0$$ $$\Phi_2 = 0 \quad \quad z<0$$
Then $$\sigma = - \epsilon_0 \frac{\partial \Phi}{\partial z}(z=0) = \frac{-qd}{2 \pi (r^2 + d^2)^{3/2}}$$
But if ##\vec{E_{above}}-\vec{E_{below}}=\sigma/\epsilon_o## then ##\frac{\partial \Phi}{\partial n}\Big|_{justabove} - \frac{\partial \Phi}{\partial n}\Big|_{justbelow} = -\sigma / \epsilon_o ## and the potential is discontinuous at z=0.
What am I doing wrong then?
The ##\underline{derivative}## of the potential in the normal direction (which is proportional to the normal component of the electric field) is discontinuous at ##z=0##
You can check from the solution that i posted earlier that ##\Phi_2(z=0) = \Phi_1(z=0)## (i'm being inconsistent with the subscripts, but 2 stands for quantities in z<0 and 1 for quantities in z>0)
Likes davidbenari
Ohh you're right I meant the derivative all this time. :confused:
So my question should really be why does ##\sigma = -\epsilon_o \frac{\partial \Phi}{\partial n}## if ##\frac{\partial \Phi}{\partial n} ## is discontinuous at z=0?
I think that's the way I phrased it originally in my OP.
Likes lautaaf
The discontinuity of ##\vec E## (and hence the discontinuity of ##\frac{\partial \Phi}{\partial n}##) ##\underline{\text{at the boundary}}## is crucial in order to have a non-vanishing surfarce charge.
Note that, if ##\frac{\partial \Phi}{\partial n}## were continuous, ##\sigma## would be identically zero.
Note also that, although ##\frac{\partial \Phi}{\partial n}## is discontinuous at the boundary, ##\Phi## is not, thus the derivative is (piecewise) well defined.
Also the derivatives ##\frac{\partial \Phi}{\partial n}## are evaluated ##\underline{\text{at the boundary}}##, so they have no dependency in z (##\sigma## is only defined at the boundary, the plate z=0): $$\sigma = - \epsilon_0 \frac{\partial \Phi}{\partial z}(z=0) = \frac{-qd}{2 \pi (r^2 + d^2)^{3/2}}$$
I
Without referring specifically to this problem, in theory, ##\frac{\partial \Phi}{\partial n}## will be discontinuous at the boundary. To picture another example: It would make no sense to evaluate ##\partial_n \Phi ## at the boundary of a spherical conductor, wouldn't it?
I think what is making things work in this specific problem is that we are differentiating the potential which is valid for ##z>0##, and thus when we evaluate ##\partial_n \Phi## using this potential we are really doing ##\partial_n \Phi'\Big|_{justabove}## where ##\Phi'## is the general potential which describes the plate and the empty space below (note that the image isn't below the plate here) . And this would work because ##\vec{E}_{above}-\vec{E}_{below}= \sigma / \epsilon_o \hat{n} ##
Could this be it?
edit: I edited a lot of poorly made sentences.
lautaaf said:
Note also that, although ∂Φ∂n\frac{\partial \Phi}{\partial n} is discontinuous at the boundary, Φ\Phi is not, thus the derivative is well defined.
How can the derivative be well defined at that point if it is discontinuous at that point?
(Yes it would work in the case of a spherical conductor. (Check Jackson's Classical Electrodynamics 3rd edition, p 58))
Perhaps if I state all the equations it will become clearer. The solution of the problem is:
$$ \Phi(r,\phi, z) \left\{
\begin{array}{l}
\Phi_1=\frac{1}{4 \pi \epsilon_0 } \bigg ( \frac{q}{\sqrt{r^2 + (z-d)^2}} - \frac{q}{\sqrt{r^2 + (z+d)^2}} \bigg ) \quad \quad z>0\\
\ \Phi_2= 0 \quad \quad \quad \quad \quad \quad \quad \quad \quad \quad \quad \quad \quad \quad \: \: z<0
\end{array}
\right.$$
And the normal derivative:
$$ - \nabla \Phi . \hat z = - \frac{\partial \Phi}{\partial z} =
\left\{
\begin{array}{l}
\frac{\partial \Phi_1}{\partial z} = \frac{q}{4 \pi \epsilon_0} \bigg ( \frac{(z+d)}{(r^2+(z+d)^2)^{3/2}} - \frac{(z-d)}{(r^2+(z-d)^2)^{3/2}} \bigg ) \quad \quad z>0\\
\ \frac{\partial \Phi_2}{\partial z}= 0 \quad \quad \quad \quad \quad \quad \quad \quad \quad \quad \quad \quad \quad \quad \: \: z<0
\end{array}
\right.$$
Now, if we want the surfarce charge:
$$ \sigma= \epsilon_0(\vec E_2 - \vec E_1) . \hat n \quad \text{at z=0}= \epsilon_0 \bigg ( \lim_{z\rightarrow 0^{-}} {\frac{\partial \Phi_2}{\partial z}} - \lim_{z\rightarrow 0^{+}} {\frac{\partial \Phi_1}{\partial z}} \bigg ) \quad \\ = \frac{-qd}{2 \pi (r^2 + d^2)^{3/2}} $$
I should have been clearer. When I said "well defined" i meant to say piecewise well defined, in the sense that the limit in the definition of the derivative exists, but is different depending on whether z<0 or z>0.
Related to Two questions related to "classical problem" of the image method
1. What is the "classical problem" of the image method?
The "classical problem" of the image method refers to a mathematical technique used to solve boundary value problems in electromagnetics and fluid mechanics. It involves creating a virtual image of a source or object and using it to calculate the solution of the problem.
2. How is the image method used in solving boundary value problems?
The image method is used by creating a virtual image of the source or object and using it to satisfy the boundary conditions of the problem. This allows for the problem to be solved using simpler and more well-known solutions.
3. What are the limitations of the image method?
The image method is limited to problems with simple geometries and boundary conditions. It also assumes that the medium is homogeneous and isotropic, which may not always be the case in real-world problems.
4. What are some real-life applications of the image method?
The image method is commonly used in the fields of electromagnetics and fluid mechanics to solve various boundary value problems. It has applications in antenna design, wave propagation, and flow around objects.
5. Can the image method be used in three-dimensional problems?
Yes, the image method can be extended to three-dimensional problems, but it becomes more complex and may not always yield accurate solutions. It is typically used in two-dimensional problems for simplicity and ease of calculation.
