Two simple questions about equivalent resistance and kirchoff laws
In summary, the conversation was about two simple questions regarding equivalent resistance and Kirchhoff's laws. The first question was about finding the resistance Rab in a given network, while the second question was about how a dead battery can be charged by connecting it to a live battery. The experts explained that the rules for equivalent resistances in parallel and series cannot be applied to the first question because the circuit does not contain resistors that are directly in parallel or series. They also clarified that current flows one way during discharge and the other way during charge in batteries due to the reversible chemical reaction. The conversation ended with a discussion on whether the 1-ohm and 3-ohm resistors are in series, with experts explaining that elements are
carlos125
two simple questions about equivalent resistance and kirchhoff laws! pleaseeeee! :D
EQUIVALENT RESISTANCE:
Hi everybody . greetings from Peru.I know it's a dumb question but help please .please read below
For the network shown in the figure, show that the resistance Rab = (27/17). Ω
This is the the soltuion I found on the internet ,
but i don't get WHY rules of equivalent resistances in parallel and series cannot be applied to this problem . obvously using those rules I get another answer which is wrong, can ayone help me please?
KIRCCHOFF:
And i have another question can a batery charge another one?
it looks like i have missed something in class because i don't understand ... like in the solution of this problem :
A dead battery is charged by connecting it to the live
battery of another car with jumper cables (Fig. P28.25).
Determine the current in the starter and in the dead
battery.
the solution says "the current is backward in the dead baterry tending to charge it up" why? ,I mean ¿what direction of current is needed so that a batery can be charged? ¿from high potntial to less potential ? i just don't get it
can someone explaian this to me please , if you have links it would be great too. Thank you very much
Because the circuit doesn't contain resistors that directly "in parallel" with another.
Hi carlos125, http://img96.imageshack.us/img96/5725/red5e5etimes5e5e45e5e25.gif
You should be able to see there is no pair of parallel resistors in that figure, nor are there two resistors in series. You need to get it clear in your mind exactly what it means for a pair of resistors to be in parallel.
battery.
If current flows out of the + terminal of a battery into an external circuit, the battery is discharging. If current flows into the + terminal of a battery from an external circuit, the battery is charging. (Assuming we are talking about secondary cells).
Thats the way batteries work. Current flows one way during discharge and the other way during charge.
If you want to know why take a look at the chemistry that goes on in a battery. Rechargable batteries use a reversible chemical reaction that creates a flow of electrons. In order to reverse the reaction you have to "push" electrons the other way, typically using a higher voltage than that of the battery.
thank you guys for your quick replies ,but aren't the 1-ohm resistance(upper left) and the 3-ohm resistance in series? . The definition for resitance in series is "Two or more elements are in series if they are cascaded or connected sequentially " ,aren't they sharing the same wire? so why aren't they in series? look:
thanks . btw the wire I'm talking about doesn't separate in two branches too , I'm confused
Elements are in series iff the exact same current that passes through one also passes through the other/s.
Elements are in parallel iff both of the ends of those elements connect to the same points.
The 1Ω and the 3Ω would be in series iff nothing was ever connected at point 'a', because with nothing connected at point 'a' those two resistors would carry the same current. But point 'a' is where the external circuit connects, delivering to those resistors unrelated and different currents.
FAQ: Two simple questions about equivalent resistance and kirchoff laws
What is equivalent resistance?
Equivalent resistance is the total resistance of a circuit when multiple resistors are connected in series or parallel. It is calculated using Ohm's law and is measured in ohms (Ω).
How do you calculate equivalent resistance in a series circuit?
In a series circuit, equivalent resistance is the sum of all the individual resistances. This means you simply add all the resistances together to get the total equivalent resistance.
How do you calculate equivalent resistance in a parallel circuit?
In a parallel circuit, equivalent resistance is calculated using the reciprocal method. This means you take the reciprocal of each individual resistance, add them together, and then take the reciprocal of the sum. The formula for this is 1/Req = 1/R1 + 1/R2 + ... + 1/Rn.
What is Kirchoff's Voltage Law (KVL)?
Kirchoff's Voltage Law states that the sum of all voltage drops in a closed loop circuit is equal to the sum of all voltage rises in that same loop. In other words, the total voltage supplied by the source is equal to the total voltage consumed by the components in the circuit.
What is Kirchoff's Current Law (KCL)?
Kirchoff's Current Law states that the total current entering a junction in a circuit is equal to the total current leaving that junction. In other words, the current flowing into a node or junction must equal the current flowing out of that node or junction.
