Two Spheres connected by a wire.
In summary, the problem involves two conducting spheres connected by a long thin wire, with radii of 5 cm and 12 cm. The electric field at the surface of the larger sphere is 830 kV/m. Using the equation E = (kQ/R^2), the surface charge density for the larger sphere is calculated to be 7.347 μC/m^2. To find the charge density for the smaller sphere, the potentials of the two spheres are set to be equal (kQ1/R1 = kQ2/R2), with the given electric field used to find Q1 and Q2.
BustedBreaks
65
Charge is placed on two conducting spheres that are very far apart and connected by a long thin wire. The radius of the smaller sphere is 5 cm and that of the larger sphere is 12 cm. The electric field at the surface of the larger sphere is 830 kV/m. Find the surface charge density on each sphere
For the 12cm sphere I used this:
[tex]E=\frac{kQ}{R^{2}}[/tex]
Solved for Q
Then divided by [tex]4\pi r^{2}[/tex], and got [tex]7.347 \frac{\mu C}{m^{2}}[/tex]
I need a little help figuring out the charge density for the 5cm radius sphere.
When the two spheres are joined by a wire, their potentials are same.
So kQ1/R1 = kQ2/R2
Or (kQ1/R1^2)*R1 = kQ2/R2.
But E = (kQ1/R1^2) is given.
Find Q1 and Q2.
Based on the given information, we can calculate the electric field at the surface of the smaller sphere using the same equation:
E=\frac{kQ}{R^{2}}
Where Q is the total charge on the smaller sphere and R is the radius of the smaller sphere.
Substituting the values, we get:
830 kV/m = \frac{kQ}{(5 cm)^2}
Solving for Q, we get:
Q = 1.037 x 10^{-10} C
To find the surface charge density, we can divide this charge by the surface area of the smaller sphere:
\sigma = \frac{Q}{4\pi (5 cm)^2}
Plugging in the values, we get:
\sigma = 1.037 \frac{\mu C}{m^{2}}
Therefore, the surface charge density on the smaller sphere is 1.037 \frac{\mu C}{m^{2}}.
FAQ: Two Spheres connected by a wire.
What is the concept of "Two Spheres connected by a wire"?
The concept of "Two Spheres connected by a wire" refers to a physical system in which two spheres are connected by a thin wire or string. This system is commonly used in physics experiments to demonstrate principles of electricity, magnetism, and mechanics.
What is the purpose of using "Two Spheres connected by a wire" in experiments?
The purpose of using "Two Spheres connected by a wire" in experiments is to create a simple and controllable system that can demonstrate various physical phenomena. This setup allows scientists to observe and study the behavior of electric charges, magnetic fields, and forces between objects.
How are the spheres connected by the wire?
The spheres are connected by a thin wire or string that is typically made of a conductive material such as copper or aluminum. The wire is attached to each sphere and provides a path for the flow of electricity or transfer of forces between the two spheres.
What are some common experiments that use "Two Spheres connected by a wire"?
Some common experiments that use "Two Spheres connected by a wire" include the Millikan oil drop experiment, the Coulomb's law experiment, the Faraday's law of induction experiment, and the Cavendish experiment to measure the gravitational constant. These experiments are important in understanding the fundamental laws of physics and have practical applications in technology.
What are some safety precautions to consider when working with "Two Spheres connected by a wire"?
When working with "Two Spheres connected by a wire", it is important to ensure that the spheres are not too close to each other or to any other metal objects, as this can lead to electric shocks. It is also important to handle the spheres and wire with care to avoid any damage or breakage. Additionally, make sure to use appropriate safety equipment, such as gloves and goggles, when working with high voltages or currents.
