Two spring-coupled masses in an electric field (one of the masses is charged)
The discussion centers on the dynamics of two spring-coupled masses in an electric field, with one mass being charged. The equations of motion are established for both particles, leading to the conclusion that the system oscillates with a frequency determined by the spring constant and mass. The center of mass accelerates due to the electric force, affecting the oscillation characteristics of both particles, which exhibit a phase difference in their motion. The challenge lies in deriving the position-time functions for each particle, particularly the amplitude of oscillation for particle A. The conversation also highlights the importance of considering inertial forces in the non-inertial center of mass frame, which complicates the analysis.
kekpillangok
The image shows two particles, A and B, attached to each other by a spring. Particle A has mass m and charge q; particle B has mass m and is electrically neutral. The spring has unstretched length l_0 and stiffness k. The system is in a region where there is an electric field E acting to the right. Neglecting friction and any electromagnetic radiation that may be emitted, find the position-time function for each particle given the following conditions:
1) When t = 0, particle A is at rest and passing through the origin of the coordinate system.
2) When t = 0, particle B is also at rest and is located at a distance l_0 from particle A.
F = ma
F_spring = -kx
X_cm = (x_1 * m_1 + x_2 * m_2) / (m_1 + m_2)
Here's what I've tried. First of all, I assume that q is positive. For particle A, then, I can write $$q E -k {\left( x _{A }-x _{B }\right) }=m \ddot{x }_{A }, $$ where ##x _{A } ## and ##x _{B } ## are the coordinates of the particles relative to their equilibrium positions from the point of view of the centre of mass. For particle B, I can write $$k {\left( x _{A }-x _{B }\right) }=m \ddot{x }_{B }. $$ Subtracting the second equation from the first gives $$q E -2 k {\left( x _{A }-x _{B }\right) }=m {\left( \ddot{x }_{A }-\ddot{x }_{B }\right) }. $$ Changing variables so that the equation has the form of a simple harmonic oscillator, I find that the angular frequency of oscillation relative to the centre of mass is $$\omega =\sqrt{\frac{2 k }{m }}. $$ This is the frequency with which each particle oscillates. Now I need to find the position-time functions for the particles, and this is where I get stuck. I know that ##x _{A }{\left( 0 \right) }=0 ## and ##x _{B }{\left( 0 \right) }=l _{0 } ##. I can also see that, at ##t =0 ##, the only force acting on particle A is the electric force, so ##\ddot{x }_{A }{\left( 0 \right) }=\frac{q E }{m } ##. Also, since there are no forces acting on particle B at that moment, I conclude that ##\ddot{x }_{B }{\left( 0 \right) }=0 ##, but this can't be particle B's equilibrium position relative to the centre of mass because its speed is zero at ##t =0## according to condition 2.
Adding the first two equations I wrote here gives $$q E =m {\left( \ddot{x }_{A }+\ddot{x }_{B }\right) }, $$ so ##a _{CM }, ## the acceleration of the centre of mass, must be equal to ##\frac{q E }{2 m } ##. The position-time function for the centre of mass, then, is $$x _{CM }{\left( t \right) }=\frac{l _{0 }}{2 }+\frac{q E }{4 m }{t }^{2 }, $$ which should be progress, but finding the position-time functions for the particles is giving me a headache. I can see that the whole system is accelerating to the right, and that it's the electric force that sets it all into motion and causes it to oscillate. There is no human being pulling the particles apart and releasing them to make them oscillate—it all starts from the electric force. I also imagine that the maximum speed of particle A relative to the centre of mass will be attained when the electric and elastic forces balance each other out; i.e., when $$x =\frac{q E }{k }. $$ ##x ## here refers to the total deformation of the spring. When the spring is deformed by that amount, then, particle A reaches its maximum speed. This need not, however, be the deformation at which B attains its maximum speed. Indeed, when A reaches its maximum speed, B is still being accelerated to the right because the elastic force is still pushing it to the right. So, when A is at its equilibrium position, ##\ddot{x }_{B }=\frac{q E }{m } ##, and I conclude that there is a phase difference in the oscillations of the two particles. When A is at maximum speed, B is still being accelerated; when A stops (relative to the centre of mass), B is at maximum speed.
I know, then, that, relative to the centre of mass, A will oscillate about the point ## x _{eq }=-\frac{l _{0 }}{2 }+\frac{q E }{2 k }.## This must be the case because the deformation of the spring is ##\frac{q E }{k } ## when the forces on A cancel each other out. Therefore A must have moved in towards the centre of mass by an amount ##\frac{q E }{2 k } ##. I should expect the position-time function for A relative to the centre of mass, then, to have the form $$ x {\left( t \right) }=-\frac{l _{0 }}{2 }+\frac{q E }{2 k }+A \cos \left( \omega t +\phi \right) \, .$$ Figuring out A (the amplitude of oscillation) is proving very difficult, however. If anyone can guide me through this one, I'll be very thankful.
When considering the dynamics of the masses relative to the CM, it is necessary to take into account that the CM reference frame is accelerating relative to the inertial lab frame. So, in the non-inertial CM frame, there will be inertial forces (fictitious forces) acting on the masses in addition to the "real" forces acting on the masses. This will invalidate some of your conclusions about the motion of the masses relative to the CM. For example, both masses actually attain maximum speed in the CM frame simultaneously.
One approach is to work out the motion relative to the CM (after including the inertial forces) and then transform the motion to the lab frame.
Another approach is to work only in the lab frame.
I found that it takes about the same amount of work for the two approaches.
Likes kekpillangok and berkeman
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
