Two Transverse Sinusoidal waves combine in a medium
In summary, two transverse sinusoidal waves with wave functions y1 = 3sin[π(x + 0.6t)] and y2 = 3sin[π(x - 0.6t)] combine in a medium and the resulting wave function is y = y1 + y2 = 6sin[πx]cos[0.6πt]. This can be obtained by using the formula sin(α + β) = sin(α)cos(β) + cos(α)sin(β). The notation of y1 and y2 can be confusing, as they represent the amplitudes of the waves. However, since sinπ = 0, both equations reduce to 0.
Willjeezy
29
Two Transverse Sinusoidal waves combine in a medium are described by the wave functions:
y1 = 3sin∏(x + 0.600t)
y2 = 3sin∏(x - 0.600t)
what is y1 + y2?
the hint is that I am supposed to use:
the answer in the back is:
y = y1 + y2 = 6sin(∏x)cos(0.600∏t)
I am not really sure how they got that. In fact,the notation of y1 and y2 confuse me because y1 says:
y1=3sin∏(x + 0.600t)
and I interpret this as 3 multiplied by sin∏ multiplied by (x+0.600t)
but the problem is sin∏ = 0, so don't both equations just reduce to 0?
y1 = 0
y2 = 0?
Can someone clarify this for me?
No. 3sin[π(x + 0.6t)] means "three times the sine of the angle π(x + 0.6t)".
hmm.3sin[π(x + 0.6t)]
it was written verbatim as:
3sin∏(x + 0.600t)
thanks, rude man.
Willjeezy said:
hmm.
I wasn't sure if it was a typo, they are missing the outer square brackets
3sin[π(x + 0.6t)]
3sin∏(x + 0.600t)
thanks, rude man.
I just added the square brackets for emphasis for your benefit.
Why would anyone write "sinπ" when that quantity is zero?
I can provide a response to this content by explaining the concept of superposition and how it applies to this problem.
Superposition is the principle that states when two or more waves meet at a point in a medium, the resulting displacement at that point is equal to the sum of the individual displacements of each wave. In other words, when two waves combine, they do not cancel each other out, but rather their amplitudes add together.
In the given problem, we have two transverse sinusoidal waves, y1 and y2, that are traveling in opposite directions along the same medium. The wave functions for these waves are given by y1 = 3sin∏(x + 0.600t) and y2 = 3sin∏(x - 0.600t). As the hint suggests, we can use the trigonometric identity sin(α + β) = sin(α)cos(β) + cos(α)sin(β) to simplify the expression for y1 + y2.
Using this identity, we can rewrite y1 and y2 as follows:
y1 = 3sin∏x cos(0.600t) + 3cos∏x sin(0.600t)
y2 = 3sin∏x cos(0.600t) - 3cos∏x sin(0.600t)
Now, when we add y1 and y2, the terms with cos(0.600t) will cancel each other out, leaving us with:
y1 + y2 = 6sin∏x cos(0.600t)
This is the same expression given in the back of the book. So, in conclusion, y1 + y2 does not reduce to 0, but rather it simplifies to 6sin∏x cos(0.600t). This shows that the combined wave has a larger amplitude than the individual waves, demonstrating the principle of superposition.
FAQ: Two Transverse Sinusoidal waves combine in a medium
What happens when two transverse sinusoidal waves combine in a medium?
When two transverse sinusoidal waves combine in a medium, they create a new wave with a different amplitude, wavelength, and frequency. This process is known as interference.
What is the difference between constructive and destructive interference?
Constructive interference occurs when two waves combine to create a larger amplitude, resulting in a wave with a higher intensity. On the other hand, destructive interference occurs when two waves combine to create a smaller amplitude, resulting in a wave with a lower intensity.
Can two transverse sinusoidal waves with different frequencies interfere with each other?
Yes, two transverse sinusoidal waves with different frequencies can still interfere with each other. However, the resulting wave will have a more complex pattern due to the different frequencies.
How does the phase difference between two waves affect their interference?
The phase difference between two waves determines whether their interference will be constructive or destructive. When the waves are in phase (i.e. their peaks and troughs align), they will experience constructive interference. When the waves are out of phase (i.e. their peaks and troughs do not align), they will experience destructive interference.
What is the principle of superposition?
The principle of superposition states that when two or more waves meet at a point, the resulting displacement at that point is equal to the sum of the individual displacements of each wave. This principle is fundamental in understanding the interference of waves.
10K
12K
