Two vehicles moving in opposite directions bonus problem
  • Thread starter antonisz
  • Tags
    Vehicles
In summary: Situation 1:Da + Db = 400Via = 30 m/sVfa = 30 m/sa = 0 m/s2da = 120 mta = ?Vave = d/ t = vf + vi /2Vave = da/tata = 4sdb = 280ta = 4s280 = c(4) + 1/2 (k)(4)2280 = c(4) + 2kSituation 2:Via = 80 m/saa = 0 m/s2vfa = 80 m/sta =
antonisz
27
Vehicle A and Vehicle B are moving in opposite directions on the NJTP. Vehicle A is heading south toward atlantic city while vehicle B is heading north towards Hoboken. In situation 1 and 2 described below, at t = 0s both vehicles are at a distance of separation of 400m and are moving towards each other.
Situation 1: When vehicle A is moving at a constant velocity of 30 m/s and travels a distance of 120 m, the vehicles pass each other on the turnpike.
Situation 2: When vehicle A is moving at a constant velocity of 80 m/s and after a time of 3s, the vehicles pass each other on the turnpike.
For vehicle A label variables as: Via, Vfa, aa, da,ta
For vehicle B label variables as: Vib, Vfb, ab,db, tb
In the ORDER INDICATED:
(a) Calculate the initial velocity of vehicle B or Vib; and
(b) Then calculate the acceleration of vehicle B or ab
Show all work in DETAIL and keep all numerical values to the nearest hundredth value. Draw and label all pictures
Note: You will receive NO CREDIT if you first calculate part (b) and then part (a)
For situations 1 and 2
vib = constant ; vfb ≠ a constant value since its value changes w/ time
ab = constant
Situation 1:
Da + Db = 400
Via = 30 m/s
Vfa = 30 m/s
a = 0 m/s2
da = 120 m
ta = ?
Vave = da/ta
ta = 4s
db = 280
ta = 4s
Situation 2:
Via = 80 m/s
aa = 0 m/s2
vfa = 80 m/s
ta = 3s = tb
da = ?
Using same equation as in situation 2,
da = 240
db=160
tb = 3s
Situation 1
db = vibtb + 1/2abtb2
280 = vib(4) + 1/2 (ab)(4)2
Situation 2
280 = vib(3) + 1/2 (ab)(3)2
280 = vi (4) + 8ab
280 - 4bi = 8ab
280 - 4vi/8 = ab
Plug this into the second equation...
160 = vib(3)+ 1/2 (280 - 4vi/8 )9
I solve and get vib = - 4/3 m/s which doesn't make sense...
So i plug that answer back into the two equations above and get ab = 35.67 m/s2 for situation 1 and for situation 2 - 34.67 m/s2.
Thank you for the help
Are you sure you didn't leave anything out? All you know for sure about vib is that it's in the opposite direction of a and changes with time. If I say vib = 1m/s, then you can solve for the acceleration using the time values, but if I say vib =2m/s then you can do the exact same thing, but you'll get a different answer.
Reread the question and make sure you didn't leave out anything important please.
I copy and pasted the file that the professor gave us. I can upload the pdf if you would like.
  • Problem7Bonus.pdf
Are you supposed to assume that the acceleration and initial speed of B is the same in both situations?
I believe so, since the problem says that both are a constant.
Good. That fact provides the 'extra' information needed to solve for them. (For each situation, B must travel a certain distance in a certain time.)
Ok, well firstly, you substituted inconsistently to get your -4/3, if ta= some number, then tb should equal that same number.
Secondly, the fact that it says vib = constant makes me thing you're just supposed to treat it as an arbitrary constant, as you litterally cannot solve this problem numerically. Set vib = c or k or lambda or whatever you like, and use that for vib, and solve for ab in terms of your constant of choice.
antonisz said:
Situation 1
Good.
Situation 2
You used the wrong distance.
Ahhh, sorry about that, I didn't think about that, but at the same time, it's not stated in the problem (at least not very clearly i.m.o.).
Doc Al said:
Good.
Sorry that was a typo on my part.
What I had on paper was 160 = vib(3) + 1/2 (ab)(3)2
So I solved for ab and I got 11.85 / vib = ab
I plugged that into the 280 = vib(4) + 1/2 (ab)(4)2 equation and I got an answer of 0.34 m/s. Which still doesn't seem right.
But continuing on I plugged 0.34 m/s into 280 = vib(4) + 1/2 (ab)(4)2 to solve for ab and received an answer of 34.82 m/s2
I'm not sure if that's what you guys got for your answer or not.
But something still feels off. I really appreciate you guys and gals taking the time out of your busy summer day to teach me some physics...lol.
Well, I didn't actually crunch the numbers, but you can always take situation a, and (knowing the time) plug in your vib and ab values and solve for the distance traveled, then check to see if that matches your starting point.
*and then do the same for situation b.
I must have messed up somewhere. Thanks anyway.
well here let me work through it and I'll see what I can find..
Thank you again, I hope I didn't make you feel like you have too lol. To be honest its probably something like a math error.
That's fine, but I'm bored at work... so...
Your answers match my own. But I agree, it does feel off. Those numbers are not very realistic. (But it's probably meant as a simple exercise, not as a physically realistic situation.)
I could see my professor giving us a bonus question like that to be honest. His name is Doc Al as well...what a coincidence! Thank you for your confirmation, I needed those 6 points!
Related to Two vehicles moving in opposite directions bonus problem
1. What is the "Two vehicles moving in opposite directions bonus problem" in science?
The "Two vehicles moving in opposite directions bonus problem" is a classic physics problem that involves two vehicles moving in opposite directions. It is commonly used to demonstrate the principles of relative motion and velocity.
2. How do you solve the "Two vehicles moving in opposite directions bonus problem"?
To solve the "Two vehicles moving in opposite directions bonus problem", you will need to use the formula d = rt, where d is the distance, r is the rate or speed, and t is the time. You will also need to take into account the direction of each vehicle's motion.
3. What are the key concepts involved in the "Two vehicles moving in opposite directions bonus problem"?
The key concepts involved in the "Two vehicles moving in opposite directions bonus problem" are relative motion and velocity. Relative motion refers to the movement of one object in relation to another, while velocity is the rate of change of an object's position over time.
4. What are some real-life applications of the "Two vehicles moving in opposite directions bonus problem"?
The "Two vehicles moving in opposite directions bonus problem" has real-life applications in various fields, such as traffic engineering, air traffic control, and space exploration. It can also be used to calculate the relative speed of two moving objects, which is important in collision avoidance systems.
5. What are some common mistakes people make when solving the "Two vehicles moving in opposite directions bonus problem"?
Some common mistakes people make when solving the "Two vehicles moving in opposite directions bonus problem" include not considering the direction of each vehicle's motion, using the wrong formula, and not converting units correctly. It is important to carefully read and understand the problem before attempting to solve it.
  • Mechanical Engineering
