Two Velocities in the Lorentz Law
In summary, Lorentz Force is represented by the equation $\vec{F}=q\vec{v_1}\times\vec{B}$, where v1 is the velocity of the particle and B is the magnetic field. The magnetic field is given by $\vec{B}=\frac{\mu_0}{4\pi}\vec{v_2}\times\frac{\hat{r}}{r^2}$, where v2 is the velocity of the particle in the wire. These two velocities are necessary to understand the relativistic effect and the length contraction for the wire. The unification of electricity and magnetism is shown in the video, as they are both aspects of the same phenomenon.
sawer
65
Lorentz Force: $$\vec{F}=q\vec{v_1}\times\vec{B}$$
v1 is the velocity of particle.
And magnetic field is: $$\vec{B}=\frac{\mu_0}{4\pi}\vec{v_2}\times\frac{\hat{r}}{r^2}$$
If we combine them, we see that there are 2 velocities:
v1 and v2...
I just watched this video about relativity and magnetism:
So v1 is the velocity of the particle and v2 is the velocity of the particle in the wire. Right?
We need both of these velocities to get the relativistic effect, I mean length contradiction for the wire. Right?
In special relativity, you need to know the relative velocities of all the objects you are interested in.
The important thing is to concentrate on what the velocity is relative to.
Off those equations:
v1 would be of the test particle wrt the magnetic field.
v2 is the effective velocity of the particles in the current - in the video, this is being modeled by a line of charge - with respect to the wire.
How much info you need depends on what you want to know and what you already know. For instance:
To get the separation of the charges in the wire, knowing the separation at some other (known) relative velocity, you only need the new relative velocity.
The unification of electricity and magnetism is what the video is trying to show you - it's not a case of one causes the other: they are both aspects of the same kind of stuff.
Related to Two Velocities in the Lorentz Law
1. What is the Lorentz Law and how does it relate to velocity?
The Lorentz Law, also known as the Lorentz force law, describes the force exerted on a charged particle by an electric and magnetic field. It is used to calculate the motion of charged particles in electromagnetic fields, and thus, it relates to velocity as it explains how the velocity of a charged particle is affected by these fields.
2. What are the two velocities in the Lorentz Law?
The two velocities in the Lorentz Law are the particle's velocity, denoted by v, and the velocity of the electromagnetic wave, denoted by c. These velocities play a crucial role in determining the magnitude and direction of the force exerted on the charged particle.
3. How does the Lorentz Law account for the effects of special relativity?
The Lorentz Law incorporates the principles of special relativity, which states that the laws of physics should remain the same for all observers in uniform motion. This is achieved by using the Lorentz transformation equations to calculate the effects of velocity on the electric and magnetic fields in the Lorentz Law.
4. What is the significance of the Lorentz Law in modern physics?
The Lorentz Law is crucial in understanding the behavior of charged particles in electromagnetic fields, which is essential in many areas of modern physics, such as particle accelerators, plasma physics, and astrophysics. It also plays a significant role in the development of technologies such as MRI machines and particle accelerators.
5. Are there any limitations to the Lorentz Law?
While the Lorentz Law accurately describes the behavior of charged particles in most cases, it does have limitations. It does not take into account quantum effects and is only valid for classical, non-relativistic particles. In extreme conditions, such as near the speed of light, the Lorentz Law may need to be modified to account for these limitations.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
26K
