Two ways to calculate the final speed of a rotating cylinder
In summary, two methods were used to calculate the final speed of a uniform cylinder rotating down a slope. The force method considered forces acting on the cylinder and the energy method equated gravitational potential energy and rotational kinetic energy. Both methods yielded the same final answer. However, there is a problem with assuming that the cylinder does no force against static friction, as it is present for rolling.
Xiao10
Situation:
A uniform cylinder (Mass [itex]M[/itex], Radius [itex]R[/itex]) is rotating down a slope of incline [itex]θ[/itex] and distance [itex] s[/itex], there are two methods which I used to calculate the final speed, one of which considered forces acting on the cylinder and the other using energy, pure rolling assumed throughout, both give the same final answer.
Force method:
1) [itex]Mgsinθ * R = \frac{3}{2} MR^2 α[/itex]
(Torque about point of contact * R = Angular acceleration * Moment of inertia)
2) [itex] Mgsinθ - F = MRα [/itex]
(Newton's Second Law, F is Friction).
After finding a to be [itex] \frac{2}{3}Mgsinθ [/itex], I then used V2= 2as to find the final speed to be[itex]\sqrt{\frac{4}{3}sgsinθ}[/itex], which is the same as that given by the...
Energy Method:
Simply equated GPE and the final rotational kinetic energy.
[itex] Mgh = \frac{1}{2}( \frac{3}{2} MR^2 )ω^2 [/itex]
Problem: The similarity of the answers assumes that somehow the cylinder does no force against static friction, which must be present for rolling.
The cylinder does no work against static friction. The part of the cylinder in contact with the ground always has zero velocity.
Not really, you have assumed that there is no work against static friction.
[edit] Hah! I was too sloow!
Related to Two ways to calculate the final speed of a rotating cylinder
1. What are the two ways to calculate the final speed of a rotating cylinder?
The two ways to calculate the final speed of a rotating cylinder are the linear velocity method and the angular velocity method.
2. How do you calculate the final speed using the linear velocity method?
To calculate the final speed using the linear velocity method, you need to know the radius of the cylinder, the initial and final positions of a point on the surface of the cylinder, and the time it takes for the cylinder to rotate from the initial to the final position. The formula is:
Final speed = (final position - initial position) / time * 2π * radius
3. What is the formula for calculating the final speed using the angular velocity method?
The formula for calculating the final speed using the angular velocity method is:
Final speed = initial angular velocity * radius * final angular position
4. How do these two methods differ in calculating the final speed?
The linear velocity method calculates the final speed based on the distance traveled by a point on the cylinder's surface, while the angular velocity method calculates the final speed based on the angle of rotation and the radius of the cylinder. The two methods may give different results depending on the specific scenario.
5. In which situations would you use each method to calculate the final speed?
The linear velocity method is more suitable for situations where the distance traveled by a point on the cylinder's surface is known, such as when the cylinder is rolling on a surface. The angular velocity method is more appropriate for situations where the angle of rotation is known, such as when the cylinder is being spun by an external force.
