Type 1 Superconductors & Static B field density
In summary, type-1 superconductors allow for localized increase in magnetic flux density, which could be used to create a larger static field.
msbe
[credit to wikipedia]
So it would appear that the type 1 meissner effect allows for the localized increase of magnetic flux density (as the displaced field must go somewhere, the B field is somewhat larger at the surfaces of the superconductor then elsewhere, and in fact is a higher value then anywhere prior to the superconducting transition.)
What would be expected to happen if this experiment could be arranged?
So basically - imagine a box made entirely of a cooled type-1 superconductor (walls thick enough that we can ignore the London penetration depth) with two holes : one just the right size to insert half of a dipole magnet, and another above this.
The flux lines of the magnet would be unable to penetrate the superconductor to loop back to the south pole, except by means of the circular hole (or in practice, whatever gap there is between the magnet and the superconductor)
Does that mean we would see a significantly larger B field at that hole? Would all the lines really be forced to travel through that area to return to the south pole?
What if the gap was removed and there was no possible return path that did not pass through the superconductor?
Or would the static field strength of the magnetic cause the superconductor to return to a normal state by exceeding its critical field density? (It seems like those values for Hc are quite high and usually occur as the result of using a superconductor as an electromagnet in particle accelerators / NMR machines / etc)
This is known as "flux focusing" and is well known. It has many applications in e.g. magnetometry (the effect can be used to "amplify" an external field). It is something one always has to consider when working with superconductors, especially thin film devices where this effect occurs all the time, the local B fields can be much higher than the applied field.
So, yes, most of what you are writing is correct; the field "has" to go through the hole. I suspect that answer to the situation without a hole would be that the field would simply go back via the magnet itself (e.g. along the surface).
Thanks, i'll have to look into this.
Are there any estimates of how large the amplification can be made? I'm curious since it would seem that with say, additional rare Earth dipole magnets and a small enough hole you could produce very large static field strengths - perhaps on par or larger then those created with high field superconducting electromagnets - albeit only in a very small area.
The focusing effect depends on the geometry, typical values are -as far as I can remember- about 10-20 at most; at least for the circuits I've designed/used.
Remmber that one limitation of this effect is the cricital field of the superconductor itself (which for type I superconductors is pretty low); this means that it can't be used to "amplify" the field to very high values. For type II superconductors (used in magnets) the limitation is the field where you instead start to create vortices (again not a very high field).
FAQ: Type 1 Superconductors & Static B field density
1. What is a Type 1 superconductor?
A Type 1 superconductor is a material that exhibits superconductivity, meaning it has zero electrical resistance and expels magnetic fields at low temperatures. These materials are typically pure metals, such as copper and aluminum, and have a critical temperature below which they become superconducting.
2. How does a Type 1 superconductor behave in a static magnetic field?
In a static magnetic field, a Type 1 superconductor will exhibit the Meissner effect, where the material expels the magnetic field from its interior and creates a perfect diamagnetic state. This means that the magnetic field density inside the superconductor will be zero.
3. What is the critical magnetic field density for a Type 1 superconductor?
The critical magnetic field density, also known as the critical magnetic field strength, is the maximum magnetic field that a Type 1 superconductor can withstand before losing its superconducting properties. This value is dependent on the material and its temperature.
4. How does temperature affect the behavior of a Type 1 superconductor in a static magnetic field?
As the temperature of a Type 1 superconductor increases, its critical magnetic field density also increases. This means it can withstand stronger magnetic fields before losing its superconducting properties. However, once the critical temperature is reached, the material will no longer exhibit superconductivity.
5. What are some practical applications of Type 1 superconductors in relation to static magnetic fields?
Type 1 superconductors have been used in a variety of applications, including magnetic levitation trains, high-speed motors and generators, and MRI machines. In these applications, the superconductors are used to create a strong magnetic field without the need for external power sources, making them more efficient and cost-effective.
