Type of Hypothesis Test to be Used
  • Thread starter 3.141592654
  • Tags
    Test Type
In summary, the problem at hand is to ensure that the mean distance of airbag inflators for automotive safety systems is at least 2.00 cm. A sample of 20 inflators yielded an average distance of 2.02 cm with a sample standard deviation of 0.05. To address this problem, a hypothesis test is used with a significance level of 0.01. The hypothesis test chosen by the professor is H_{0}: \mu = 2.00 cm vs. H_{1}: \mu > 2.00 cm, as this provides strong evidence for the company's desired outcome. Testing for H_{1}: \mu < 2.00 cm would not inspire confidence in the consumer and
85
Problem Statement
In the production of airbag inflators for automotive safety systems, a company is interested in ensuring that the mean distance is at least 2.00 cm. Measurements on 20 inflators yielded an average value of 2.02 cm. The sample standard deviation is .05 on the distance measurements and use a significance level of .01.
Attempted Solution
This is a problem that my class worked through in lecture, so I'm not looking for the answer. Instead, I'm trying to determine why the following hypothesis test was used by my professor:
[itex]H_{0}: \mu = 2.00 cm[/itex]
[itex]H_{0}: \mu > 2.00 cm[/itex]
My interpretation of the problem is that some company needs to ensure that [itex]\mu \geq[/itex]2.00 cm. So by doing the hypothesis test outlined above we'll either conclude the mean is 2.00 cm or it is greater than 2.00 cm, which are both equally acceptable to the company. The alternative scenario, that the mean is less than 2.00 cm, isn't tested. But that's what the company needs to worry about. So shouldn't we test:
[itex]H_{0}: \mu < 2.00 cm[/itex]
Thanks.
You need an [itex] H_1 [/itex].
Statistics is subjective. The hope of the company is presumably to offer strong evidence that [itex] \mu \ge 2.0 [/itex]. If they test for [itex] \mu \lt 2.0 [/itex] it's as if they are saying "Go ahead. Let's see if you can prove [itex] \mu \lt 2.0 [/itex]". That doesn't inspire confidence in the consumer who buys the airbag inflator. Compare which side of the question gets the benefit of the doubt if the result is only significant at the 0.05 level.
Related to Type of Hypothesis Test to be Used
What is a hypothesis test?
A hypothesis test is a statistical method used to determine whether there is enough evidence to reject or support a hypothesis about a population parameter. It involves collecting and analyzing data to make an inference about the population based on a sample.
What is the purpose of a hypothesis test?
The purpose of a hypothesis test is to make a decision about a population parameter based on a sample. It helps us determine whether our sample results are representative of the entire population or if they occurred by chance.
What are the different types of hypothesis tests?
There are three main types of hypothesis tests: the Z-test, the t-test, and the ANOVA test. The Z-test is used for large sample sizes (n > 30) and when the population standard deviation is known. The t-test is used for smaller sample sizes (n < 30) and when the population standard deviation is unknown. The ANOVA test is used to compare the means of three or more groups.
How do I choose which type of hypothesis test to use?
The type of hypothesis test to use depends on the research question and the type of data being analyzed. If the research question involves comparing two means, then a t-test should be used. If the research question involves comparing more than two means, then an ANOVA test should be used. It is important to also consider the sample size and the distribution of the data when choosing a hypothesis test.
What are the steps involved in conducting a hypothesis test?
The steps involved in conducting a hypothesis test include: 1) stating the null and alternative hypotheses, 2) selecting a significance level, 3) calculating the test statistic, 4) determining the critical value or p-value, 5) comparing the test statistic to the critical value or p-value, and 6) making a decision to reject or fail to reject the null hypothesis.
