Types of energy in a gas discharge tube
In summary, gas discharge tubes involve the ionization of gas by an electric field created by two electrodes. The power source provides electrical energy, which is converted into electrostatic potential energy within the electrodes and then transferred to the gas ions. The ions are then accelerated towards the electrodes, converting the electrostatic potential energy into kinetic energy. This kinetic energy is transferred to the electrodes and back into the power source or lost through collisions. Additionally, the gas in the tube is heated and emits light due to the movement of charges and transitions between energy states. The electrodes maintain a steady-state situation where they are not gaining or losing energy while the power source is on. Overall, the process involves multiple forms of energy conversion and transfer.
Bhope69199
42
I am reading about gas discharge tubes and can't work out the types of energy and energy conversion that occurs in a gas discharge tube.
Initially before the tube is switched on you have an inert gas with kinetic energy.
As soon as the tube is switched on there is an an electric field between two electrodes which ionises the gas. The energy is provided by the power source as say chemical energy. This chemical energy is being converted into electrostatic potential energy within the electrodes. This electrostatic potential energy is transferred through the electric field to the gas ions.
This electrostatic potential energy is then converted to kinetic energy once the ions are accelerated towards the electrodes.
Once they hit the electrodes this kinetic energy is transferred to the electrodes and back into the power source or lost through the collision with the electrode.
Do the electrodes lose electrostatic potential energy once the gas is ionised (as it is being transferred to the gas ions?)? And is this being replaced by the movement of electrons to the electrodes by the power source? (Chemical energy into electrostatic potential energy in the case of a battery?)
Is this process of energy transfer correct in this case and are there any other energy transfers that I am missing?
Thanks.
An important characteristic of gas discharges is in many cases, besides atoms being ionized and thereby creating free electrons, there are also atoms with excited electronic states of their atoms. Both ions and free electrons, and excited electronic states can result in spectral lines as the atom transitions to a lower energy state. In addition , mostly from the plasma (ionized gas) itself, there can be a blackbody type (continuous spectrum roughly following the Planck blackbody function) spectral output from these lamps in addition to atomic spectral lines.
That's right.
The power source provides electrical energy in the form of a current and voltage.
Several things are happening in the gas. Electrons are being ripped out of their orbitals by the electric field and by collisions between high-energy electrons or atoms. These free electrons then have both kinetic energy and several forms of potential energy (since they can be captured by another ionized atom, releasing energy, and they are also in an electric field). Overall, the influx of energy from the electrodes heats the gas in the tube, increasing its internal energy (kinetic + potential). All this moving about of charges and transitions between energy states releases energy in the form of light. Heat is also lost, transferred from the gas to the lamp glass and then to the environment. Shortly after being switched on, the lamp reaches equilibrium where the energy being released from the lamp in the form of light and heat equals the energy input to the lamp.
While the power source is turn on, the net effect is that the electrodes maintain a steady-state situation where they aren't losing or gaining any net energy. You can try to talk about what happens to individual electrons, but even that's a bit difficult as there are many different things happening at the electrode-gas boundary. Furthermore, energy isn't transferred to the electrodes solely through electrons. The electromagnetic field is how most of the energy is transferred from the power source to the electrodes and then to the gas.
That's my understanding at least.
Likes Charles Link
Related to Types of energy in a gas discharge tube
What is a gas discharge tube?
A gas discharge tube is a sealed glass tube filled with a gas, usually at low pressure, that allows for the flow of electrical current through it.
What are the different types of energy in a gas discharge tube?
The three main types of energy in a gas discharge tube are electrical energy, thermal energy, and radiant energy.
How is electrical energy produced in a gas discharge tube?
Electrical energy is produced when an external voltage is applied to the gas discharge tube, causing electrons to flow from the negative electrode (cathode) to the positive electrode (anode). This flow of electrons creates an electric current.
What is thermal energy in a gas discharge tube?
Thermal energy in a gas discharge tube is the heat energy produced by the collisions between electrons and gas atoms or molecules. This thermal energy can cause the gas to glow and emit light.
What is radiant energy in a gas discharge tube?
Radiant energy in a gas discharge tube is the energy emitted in the form of light or other electromagnetic radiation. This energy can be produced through the excitation and de-excitation of gas atoms or molecules by the movement of electrons.
  • Electromagnetism
  • Beyond the Standard Models
  • Electromagnetism
