U ^ 5/2 /5/2 - u^ 1/2/3/2 +c intergration
In summary, the formula for integrating U ^ 5/2 /5/2 - u^ 1/2/3/2 +c is ∫u^5/2/5/2-u^1/2/3/2+c du. The process for integrating U ^ 5/2 /5/2 - u^ 1/2/3/2 +c involves using the power rule for integration, subtracting the exponents, and adding a constant of integration at the end. The integration of U ^ 5/2 /5/2 - u^ 1/2/3/2 +c can be solved without a calculator as long as the integration techniques are properly applied. Common mistakes
morbello
73
[tex]\int\sqrt{1+x} dx =[/tex]
[tex]\int (u-1)\sqrt{u} du[/tex]
were does the 3/2 and the 1/2 come from in
u ^ 5/2 /5/2 - u^ 1/2/3/2 +c
Mathematics news on Phys.org
They come from the exponents of u.
[tex](u-1)\sqrt{u} = u\sqrt{u}-\sqrt{u} = u^{3/2} - y^{1/2}[/tex]
so
u\sqrt{u} = 3/2 ok i remember some thing from my previouse course saying that thank you again for your help.
Related to U ^ 5/2 /5/2 - u^ 1/2/3/2 +c intergration
What is the formula for integrating U ^ 5/2 /5/2 - u^ 1/2/3/2 +c?
The formula for integrating U ^ 5/2 /5/2 - u^ 1/2/3/2 +c is ∫u^5/2/5/2-u^1/2/3/2+c du.
What is the process for integrating U ^ 5/2 /5/2 - u^ 1/2/3/2 +c?
Can the integration of U ^ 5/2 /5/2 - u^ 1/2/3/2 +c be solved without a calculator?
Yes, the integration of U ^ 5/2 /5/2 - u^ 1/2/3/2 +c can be solved without a calculator as long as the integration techniques are properly applied.
What are the common mistakes to avoid when integrating U ^ 5/2 /5/2 - u^ 1/2/3/2 +c?
The common mistakes to avoid when integrating U ^ 5/2 /5/2 - u^ 1/2/3/2 +c include forgetting to add the constant of integration, mistakenly changing the sign of the exponents, and incorrectly applying the power rule.
What are some real-life applications of U ^ 5/2 /5/2 - u^ 1/2/3/2 +c integration?
U ^ 5/2 /5/2 - u^ 1/2/3/2 +c integration can be used in physics to calculate the work done by a variable force, in economics to determine the total cost of production, and in engineering to calculate the displacement of a variable velocity object.
  • General Math
  • Calculus
  • General Math
  • General Math
