U-shaped tube different diameters. What level will water assume?
In summary: So in summary, the overflow of the downpipes and slow flow into the tank may be due to a lack of pressure caused by the 1.5m distance between the two pipes. Changing the pipe diameter would not help and bypassing the tank may be a potential solution to test. Friction in the pipes is also a factor contributing to the slow flow.
Doodad
I have a problem wih my gutters overflowing and I wonder if it is because of the weight of water in the two sides of the downpipes. Essentially I have 90mm downpipes which go underground into 100mm pipes which then come back above ground and empty into a water tank. I am finding that my downpipes are overflowing and at the same time the water is only flowing slowly into the tank. The top of the tank is about 1.5m below the top of the downpipes.
So the question is if you have a U shaped pipe where each side is a different diameter will the level of water in both side be the same or does the weight of water in the larger side slightly overcome the smaller?
The weight isn't really the important part, the pressure is. A siphon will work even if the tube is not equal diameter everywhere. It seems more likely to me that either the pipe is not airtight (in which case you never get the siphon working) or it is clogged somewhere with debris.
I don't think the pipe will be airtight because there are four downpipes leading to the one "main pipe" underground. Although I guess once all the pipes are full that "should" make it airtight?
We have had a camera down the pipes to make sure it isn't blocked that is why I am trying to think of a physics reason why it isn't working properly!
Does the tank have an opening at the top to let the air escape?
Yes the pipes are slightly above the tank and just pour into the top. When the downpipes overflow the water coming out of the pipe does not come out with force it just pours out gently.
Well, it probably wouldn't come out very fast with only 1.5 meters. Does this only happen in heavy rain? It may be just too much water and not enough vertical distance between the input of the downpipes and the output. If the pipe entered the tank at the bottom it would work better, until the tank fills up.
I guess I am trying to understand why the 1.5m is an issue. I would have thought that once the level of the water in the downpipe went above the level of the top of the pipe emptying into the tank then the water should be coming out like a fire hose because the water should be trying to maintain a common level.
This is why I started thinking maybe it is an issue with the different diameters whereby the pressure of the larger diameter pipe was slightly overcoming the pressure bearing down from the downpipes. If this is a factor I can get them to change the pipes leading up to the tank to 90mm
As for whether it only happens in heavy rain the answer is no in my opinion. The rain hasn't been torrential and the pipes have still overflowed.
1.5 m of water corresponds to 0.15 atmospheres of pressure. That may not be enough pressure to drive the water through that length of pipe an more than the sluggish pace you have seen.
Decreasing the pipe diameter would not help. If anything it would make it worse. I think I would try bypassing the tank just to see if it would help. Just let the water run out on the ground instead of running it up the side of the tank. Sorry, I don't know of anything else.
OK so I am wrong in assuming that once the pipe fills with water that it will quickly maintain a common level. I assume it is friction in the pipe that prevents the flow?
Correct. The water will seek an equilibrium height between the two pipes, but the flow rate between the two depends on the pressure, which is a function of the height difference.
FAQ: U-shaped tube different diameters. What level will water assume?
What is a U-shaped tube with different diameters?
A U-shaped tube with different diameters is a scientific apparatus used to demonstrate the principle of hydraulic pressure. It consists of a tube bent into a U-shape with one side having a larger diameter than the other.
How does the U-shaped tube with different diameters work?
The U-shaped tube works by filling both sides with a liquid, usually water, and then observing how the liquid levels in each side respond to changes in pressure. When pressure is applied to one side, the liquid will flow through the tube and reach an equilibrium point where the liquid levels are equal. This is due to the principle of Pascal's law, which states that pressure applied to a confined fluid will be transmitted equally in all directions.
Why is the water level different in each side of the U-shaped tube?
The water level is different in each side of the U-shaped tube because of the difference in diameter. The smaller diameter side has a higher pressure due to the same amount of water being compressed into a smaller area. This results in the water level being higher on that side compared to the larger diameter side.
How does changing the diameter of the tube affect the water level?
Changing the diameter of the tube will affect the water level by changing the amount of pressure applied to the liquid. A smaller diameter will result in higher pressure and a higher water level, while a larger diameter will result in lower pressure and a lower water level.
What level will the water assume in a U-shaped tube with different diameters?
The water will assume an equal level in both sides of the U-shaped tube when the pressure is equal on both sides. However, if the pressure is unequal, the water will always be higher on the smaller diameter side due to the principle of Pascal's law.
