Ubuntu 14.04, wireless network cannot connect
In summary: The networks are detected and show up in the network manager, but when I connect and insert the correct password (double checked), a window continues to pop up saying that I need to authenticate my password. ... this seems to be a common issue.One solution worked ONCE, by turning on airplane mode and off again, but I've tried to do this again and it doesn't have the original effect. ... this is also a common issue.Can anybody help? ... unfortunately, no.
Bussell93
I have recently installed ubuntu 14.04 alongside windows 7 but I'm having major issues with connecting to wireless networks.
The networks are detected and show up in the network manager, but when I connect and insert the correct password (double checked), a window continues to pop up saying that I need to authenticate my password. I've searched for a solution online everywhere and tried everything.
I use Ubuntu to computer program but do not have a very good knowledge of the technical side of the operating system.
Can anybody help?
Computer science news on Phys.org
Sounds like a server message - have you asked the sysadmin?
Have you tried on other networks?
What is the exact error message?
Its my home laptop, so who is the sysadmin, me?
I've tried on other networks at university and managed to get them to work, but when I'm at home it doesn't connect. The exact error message just asks me to re-enter my network password, but I know its correct.
Have you ever connected to your home network with this computer and this version of ubuntu?
yes, once. I managed to connect yesterday after restarting airplane mode, but after doing the same today that method didn't work.
and when you connected you were able to browse some websites?
I've had similar problems too and had to go thru a checklist of things:
1) can the computer connect via wired connection and browse?
if yes means the wireless in your home is the problem
if no means the network to your home is the problem
2) has the computer ever connected?
if no means that maybe youve configured it wrong like using the wrong password or wrong wifi security setting
if yes then maybe the computer is too far from the wifi box or its latched on to some other network wifi
sometimes you can connect to the wifi but the network to your house is not working
sometimes you need to power on reset the cable modem or wifi router...
You are root on your own laptop, but who is the admin for your home network/router? It sounds to me like you are authenticated to the access point but there is another layer to go through.
You should still go through jedishrfu's checklist.
... this is what leads me to suspect that it is not exactly Ubuntu that is the problem. Just checking: you were able to connect to your home network in the previous release without problems?
... write out the error message word-for-word and put it on it's own line please. Don't just paraphrase.
Attempting to connect from the commandline usually reveals more information than the GUI dialogs.
Have a read through:
http://www.blackmoreops.com/2014/09/18/connect-to-wifi-network-from-command-line-in-linux/
http://linhost.info/2008/12/ubuntuconnect-to-an-access-point-from-the-command-line/
It can be firmware or something like that - Ubuntu devs seems to yoyo about how much they will support proprietary stuff by default in new installs. Have you seen:
http://www.linux.org/threads/cannot-connect-to-wifi-at-home-after-upgrade-to-ubuntu-14-04.5873/
http://askubuntu.com/questions/454325/cannot-connect-to-wifi-at-home-after-upgrade-to-ubuntu-14-04
Related to Ubuntu 14.04, wireless network cannot connect
1. Why won't my wireless network connect on Ubuntu 14.04?
There could be several reasons for this issue. It could be due to a faulty wireless adapter, incorrect network settings, or compatibility issues with your router. It is recommended to troubleshoot the issue by checking your network settings, restarting your router, or trying a different wireless adapter.
2. How do I fix a "No wireless interface found" error on Ubuntu 14.04?
This error usually occurs when the correct drivers for your wireless adapter are not installed. You can try installing the drivers manually or using a tool like Additional Drivers in the Ubuntu Software Center. If that doesn't work, you may need to update your kernel or seek help from the Ubuntu community.
3. Can I connect to a hidden wireless network on Ubuntu 14.04?
Yes, you can connect to a hidden wireless network on Ubuntu 14.04. To do so, open the network menu and click on "Connect to Hidden Wi-Fi Network." Then, enter the network name, security type, and password. You may also need to adjust your network settings to allow for connections to hidden networks.
4. Why does my wireless network keep disconnecting on Ubuntu 14.04?
This could be due to interference from other electronic devices, outdated network drivers, or an unstable wireless connection. To fix this issue, try moving closer to your router, updating your drivers, or changing the wireless channel on your router.
5. How do I reset my network settings on Ubuntu 14.04?
To reset your network settings, you can use the command "sudo systemctl restart NetworkManager" in the terminal. This will restart the network manager and refresh your network settings. You can also try resetting your router or reconnecting to your wireless network from scratch.
  • Computing and Technology
