Udemy Quiz Question on Radians and Quadrants
In summary: Welcome, @Simone !Maybe it wasn't explained well. Other guys got it so it was probably... understandable?
Simone
TL;DR Summary
Why is the answer "on the positive vertical axis" and not "in the third quadrant?" the question on the quiz is: Where is an angle of 10.5π radians in standard position located?
Is there a difference between 10.5 radians and 10.5π radians?
I am so stupid, this question makes me want to cry.
Question: Where is an angle of 10.5π radians in standard position located?
A. On the positive vertical axis
B. On the negative vertical axis
C. In the second quadrant
D. In the fourth quadrant
I thought I had to divide 10.50 by 3.14, which I thought yielded 3.34π. Then I subtracted 3.34π by 2π to get 1.34π. That is 3rd quadrant.
I also tried 3.34π times 180° which yielded 601.2°. That is also in the third quadrant. Clearly not an answer choice.
I hate how stupid I am. I don't know why I can't understand such a simple question. Please explain in simple terms, step-by-step.
Mathematics news on Phys.org
Correct IF THERE WAS NOT A MULTIPLIER OF ##\pi = 3.14159##. But there is a multiplier of ##\pi##, so it is easier. ##10.5\pi / \pi = 10.5## That is 5 full circles plus one-fourth of a circle in the counterclockwise direction. That is on the positive verticle axis.
How are 10.5 radians and 5.25 rotations? By dividing 10.5π by π it becomes radians without pi... so would I then still divide by 3.14 since the multiplier is gone? I feel I am missing something fundamental here, im sorry.
Why did you divide by π instead of 2π? How did you know to divide by any multiple of π in the first place? How did you get 5.25 rotations from 10.5? What do you mean by a multiplier of π? Is there a difference between 10.5 radians and 10.5π radians? If so, what is it?
The difference is that ##10.5\pi## has a multiplier of ##\pi=3.14159265358979....##. That is quite different from 10.5
##10.5\pi = 32.9867228626928##.
Now you can proceed as you did before and divide 32.9867228626928 by 3.14159265358979, but it is easier to just leave ##\pi## there symbolically so that it cancels cleanly with no calculations: ##10.5\pi / \pi = 10.5##.
Likes PeroK
Is there a difference between 10.5 and 10.5 * ##\pi##?
For a problem like this, it's better to just visualize the Unit Circle instead of trying to plug in numbers for ##\pi## -- Just remember that there are ##2 \pi## radians in a a circle, and the rest is easy:
https://precalctrig.weebly.com/4-unit-circle.html
Likes Lnewqban and FactChecker
… And just in case you ever wonder why such impractical way to measure angles has been used:
”In calculus and most other branches of mathematics beyond practical geometry, angles are measured in radians. This is because radians have a mathematical naturalness that leads to a more elegant formulation of some important results.
Results in analysis involving trigonometric functions can be elegantly stated when the functions' arguments are expressed in radians.”
Copied from
https://en.wikipedia.org/wiki/Radian
:cool:🎄
Likes Simone
10.5 π radians represents 5.25 rotations. 10.5 radians represents and angle of about 601.1 degrees.
Why would you want to divide 10.5π by π?
Likes Simone
No. ##\pi## is the 3.14 (actually it is 3.14159265358979.... ) So rather than multiplying out the ##10.5\pi## and then dividing by ##\pi##, it is simpler to just symbolically cancel the ##\pi##s.
Likes Simone and pinball1970
I did not like the concept at 16, why do it like that? Why not just degrees?
Perhaps it was not explained that well? Other guys got it so it was probably just me!
Likes Simone
Perhaps we should use ##\tau## instead of ##\pi##?
https://tauday.com/tau-manifesto
  • Wow
Likes Simone, Lnewqban and pinball1970
So that the fourth derivative of the ##\sin## function is the ##\sin## function instead of the fourth power of ##\frac{\pi}{180}## times the ##\sin## function. Well, that and a few thousand other things where radians keep factors of ##\pi## and ##180## out of our formulas.
  • Wow
Likes Lnewqban, Mark44 and pinball1970
Fourth derivative? Is that snap crackle or pop?
It will be one of those. Let us see which....
If we normalize a particle in simple harmonic motion to an angular frequency of one positive radian per time unit, a phase of zero at time zero and an amplitude of one distance unit then the position function will be ##x = \sin t##
The velocity will be ##v = \cos t## (first derivative of ##\sin t##).
The acceleration will be ##a = -\sin t## (second derivative of ##\sin t##)
The jerk will be ##j = -\cos t## (third derivative of ##\sin t##)
The snap will be ##s = \sin t## (fourth derivative of ##\sin t##).
Conveniently, there are no factors of ##\pi## or ##180## anywhere except in the step where we normalized things.
Edit: Changed position from "##s##" to "##x##" to avoid the conflict with snap.
Likes pinball1970
FAQ: Udemy Quiz Question on Radians and Quadrants
What is a radian?
A radian is a unit of measurement for angles, equal to the angle subtended by an arc of a circle with the same length as the radius of the circle. It is denoted by the symbol "rad" and is used in trigonometry and calculus.
How do you convert degrees to radians?
To convert degrees to radians, you can use the formula: radians = (π/180) * degrees. This means that to convert degrees to radians, you multiply the number of degrees by π/180.
What is the difference between radians and degrees?
Radians and degrees are both units of measurement for angles. The main difference between them is that radians are based on the radius of a circle, while degrees are based on dividing a circle into 360 equal parts. Radians are often preferred in mathematics and physics because they make calculations involving circles and angles simpler.
What are the quadrants in a coordinate plane?
The quadrants in a coordinate plane are the four regions formed by the x-axis and the y-axis. They are numbered counterclockwise starting from the upper right quadrant, which is known as the first quadrant. The other quadrants are the second quadrant (upper left), third quadrant (lower left), and fourth quadrant (lower right).
How do you determine the quadrant of an angle?
To determine the quadrant of an angle, you need to look at the sign of the x and y coordinates of the point where the angle intersects the unit circle. If both coordinates are positive, the angle is in the first quadrant. If the x-coordinate is negative and the y-coordinate is positive, the angle is in the second quadrant. If both coordinates are negative, the angle is in the third quadrant. And if the x-coordinate is positive and the y-coordinate is negative, the angle is in the fourth quadrant.
