Ultraviolet Catastrophe & the Photoelectric Effect
In summary, the conversation discusses the UV catastrophe and classical physics' understanding of the emission of electromagnetic radiation from objects. It also touches on the use of a gold leaf electroscope to demonstrate the photoelectric effect and the role of charging in the experiment. The conversation highlights the limitations of classical physics in explaining these phenomena.
Jimmy87
686
Hi,
Please could somebody verify if what I have understood about the UV catastrophe is along the correct lines. I used this hyperphysics link:
(http://hyperphysics.phy-astr.gsu.edu/hbase/mod6.html)
Is it saying that using classical physics an object like a pen should be emitting just as much UV light as infrared? The way I understand it is that an object like a pen is absorbing energy all day but also emitting the energy back and this energy being emitted back should have equal probability of being infrared, visible, UV (as per the table in the above link)? So as an example, let's say after 5s a pen absorbs 100eV of energy from the room. Since UV photons have an energy of around 10eV then this energy could hypothetically (at least classically) be emitted back as 10 UV photons rather than what actually happens which is that 100 infrared photons (1eV each) are emitted back. Is this basically what classical physics had to say about what EM radiation objects should emit?
Could someone also explain why a gold leaf electroscope has to be charged before it demonstrates the photoelectric effect. In all online demos I have seen a charged rod is brought close and the person touches the top to allow electrons to flow onto the electroscope causing the leaf to stay deflected after the rod is removed. Why can't a neutral electroscope be used? If it is not charged initially then the leaf would be down but if you shine UV light on the top then surely electrons would still come off leaving the electroscope positively charged and therefore the leaf would start to rise?
Jimmy87 said:
Hi,Is it saying that using classical physics an object like a pen should be emitting just as much UV light as infrared?
Not exactly. classical physics do not operate with "photons" at all, it just produce Raileigh-Jeans law which is grossly inaccurate at ultraviolet wavelengths exactly because it does not take quantization into account.
https://en.wikipedia.org/wiki/Rayleigh–Jeans_lawRelating electroscope effect charging by photoelectron emission instead of discharging, the effect do definitely exist but simply much weaker (by factor of ~100) so experiment is difficult to perform.
Likes Jimmy87
Related to Ultraviolet Catastrophe & the Photoelectric Effect
1. What is the Ultraviolet Catastrophe?
The Ultraviolet Catastrophe is a phenomenon in classical physics where the amount of energy emitted by a blackbody at high temperatures is predicted to be infinite, which contradicts experimental observations.
2. How was the Ultraviolet Catastrophe resolved?
The Ultraviolet Catastrophe was resolved by Max Planck in 1900 through the introduction of the concept of quantization, where energy is emitted in discrete packets rather than continuously. This led to the development of quantum mechanics.
3. What is the Photoelectric Effect?
The Photoelectric Effect is the emission of electrons from a metal surface when it is exposed to light. The electrons are emitted with a characteristic energy depending on the frequency of the light.
4. What is the significance of the Photoelectric Effect?
The Photoelectric Effect was one of the key experiments that led to the development of quantum mechanics. It also provided evidence for the particle nature of light, as well as the concept of the photon.
5. How did the Photoelectric Effect contribute to the understanding of the Ultraviolet Catastrophe?
The Photoelectric Effect played a crucial role in resolving the Ultraviolet Catastrophe. It showed that the energy of emitted electrons is dependent on the frequency of the incident light, rather than its intensity. This supported Planck's theory of quantization and helped to explain the observed deviation from classical predictions in the Ultraviolet Catastrophe.
