MHB Un-clear proof of my professor - logic and theory set
The discussion revolves around a logic and set theory problem where a student questions their professor's proof approach. The student initially misunderstands the proof's structure, believing it should address all cases where a condition holds. However, the response clarifies that the professor's proof only needs to demonstrate that a specific case leads to the desired conclusion, rather than all possible cases. The distinction between universal quantification and specific instances is emphasized, highlighting that proving a general statement does not require exhaustive case analysis if the implication holds in the given context. This nuanced understanding of logical implications is crucial in set theory proofs.
dana1
hey all, I am currently studing logic and set theory.
My professor solved this question in a way that seems quit strange to me-
Hope you could be of help.
I attached the question in image file so signs won't be lost
Hi dana! Welcome to MHB! :)
It seems you have made a typo.
Can it be that you meant: "shouldn't she look at the case that will give p=true and prove that if follows that q=true"?
If so, that is exactly what she did.
She assumed that $p$=true.
In other words, that:
$$\forall C(A\cup B = B \cup C)\qquad (1)$$
From here she wanted to prove that $q$=true, meaning:
$$A=B\qquad\qquad\qquad\qquad (2)$$
So the question is if we can up with a chain of deductions that leads from (1) to (2).
Now perhaps I am misunderstanding you.
Can you explain?
Can you explain?
hey Serena,
thanks for answering. Yes I had a typo- I ment if q=t then p=t.
my confusion is that she didnt say anything about all cases where p=t and c isn't the empty set. because see should prove this is correct for all cases not just one. am I correct?
dana said:
hey Serena,
That sounds as if you would like to proof that $\forall C$ we have that:
$$(A\cup C = B \cup C) \to (A=B)$$
which can also be written as:
$$\forall C((A\cup C = B \cup C) \to (A=B))$$As opposed to:
$$(\forall C(A\cup C = B \cup C)) \to (A=B)$$
How does that look as a difference?
There are some $A,B,C$'s for which is is NOT true that:
$A \cup C = B \cup C \implies A = B$.
For example, if $A,B \subseteq C$, but $A \neq B$, then $A \cup C = B \cup C = C$.
To see why your professor's proof works, consider this statement:
"If John knows everyone, then John knows Sally".
We do not need to argue that since John knows Sam, John knows Sally; and since John knows Tom, that John knows Sally; etc., some of which may not even be true (for example, none of the forgoing statements are true in and of themselves, as it is possible to imagine the case where John knows Tom, but John does not know anyone BUT Tom).
We merely need to observe that since, in particular, Sally is part of "everyone", we have: John knows Sally implies John knows Sally, which is always true.
A statement like: "For all (something), such-and-such involving (something) is true" is a shorthand way of saying:
For something A it is true AND
for something B it is true AND
for something C it is true AND...etc.
If the truth of the statement for "something X" implies the conclusion we are after, that is the only case we need.
Contrast this with a statement like:
If $A \cup C = B \cup C$, then $A = B$. Here, we DO have to consider the truth value of every statement involving the $C$ part, because if we find even ONE $C$ for which $A \cup C = B \cup C$ is true, but $A = B$ is false, we have:
true implies false, which is false.
It's a subtle distinction, but the range (which part of the statement it applies to) of the quantifier "for all" makes a BIG difference.
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
