Is Unbiasedness in Estimation Truly Reflective of Population Parameters?
  • I
  • Thread starter fog37
In summary: We have to develop it in a way that is still logically consistent, but it is challenging. In particular, the definitions of things like "bias" and "unbiased estimator" are not entirely satisfactory. It is better to simply state that an estimator is biased or not, or that it has a positive or negative bias. But, as you say, it is common to say that an estimator is unbiased if its expected value is equal to the parameter it estimates. So we accept that as a concept. It doesn't lead to a contradiction or anything.In summary, the conversation discusses the concept of unbiased estimators and their importance in statistical analysis. The goal is to have estimators that are as accurate
fog37
1,569
108
TL;DR Summary
Unbiasdness of estimates
Hello (again).
I have a basic question about standard error and unbiased estimators.
Let's say we have a population and with a certain mean height and a corresponding variance. We can never know these two parameters, the mean and the variance, and we can only estimate them. Certainly, the more accurate the estimates, the better.
To achieve that, we want out estimators to be unbiased so the expectation value of the mean "tends" to the actual population mean. This unbiasdness is rooted in the theoretical idea that if we took many many many many samples and calculated their mean and created the sample distribution of the means, the mean of the means would be the actual population mean. However, the sample means are all different from each other, some are close to the true mean some are very off...The standard error of the sample mean is essentially the variance of that normal sampling distribution telling us how much the various sample means differ from each other.
That said, assuming it is correct, we only work with a single sample of size ##n## and have a single sample mean whose value could still be very very far from the actual mean, i.e. we could be very off! Isn't that a problem? The idea that ##E[sample mean]=true mean## seems very abstract. I know that, in statistics, we always have not choice but to deal with uncertainty...I guess knowing that ##E[sample mean]=true mean## gives us a little more confidence that our sample statistics is a decent result? It is a better type of uncertainty than other uncertainties...
The same idea applies to ##95% ##confidence intervals: if we took a million samples and calculated their ##CI##, the true population means would be captured inside 95% of those sample CI intervals. That is an interesting result but, working with a single sample as we always do, it may be well possible that our constructed ##CI## does not contain the true population parameter!
Thank you!
Yes, what you say is correct.
However, it is not the only way to look at these issues. Instead of considering that there is a "true mean" at all you can instead consider the population mean itself to be a random variable. That is Bayesian probability.
Likes fog37
I see. I am not there yet to get into Bayesian probability :)
Another thing I am wondering:
in statistics, lots of sophisticated statistical tests are run to check for key assumptions being verified or not. For example, when we create a model using OLS, the estimates can be not trustworthy if the assumptions about the residuals are not met...
In machine learning, working with lots of data, the main concern are the performance metrics assessing how good the model is....It is all about prediction and less about inference, correct? Does that mean that all those statistical test are less of a concern when the amount of data is large and the goal is prediction?
thanks!
To me, it doesn't seem abstract to say that the formula we use has the same expected value as the correct answer.
True, but you have 95% confidence that the ##CI_{95}## contains the true value. And if you want more confidence, you can work with other common confidence levels like 97.5% or 99%, which just expands the intervals to cover more.
In estimating the variance, ##\sigma^2##, of a random variable, you might consider ##\sum {(X_i-\mu)^2}/n##, ##\sum {(X_i-\bar X)^2}/n##, or ##\sum {(X_i-\bar X)^2}/(n-1)##.
1) ##\sum {(X_i-\mu)^2}/n## is unbiased, but it requires knowledge of the true population mean, ##\mu##.
2) ##\sum {(X_i-\bar X)^2}/n## uses the sample mean to estimate ##\mu##, but it is biased. It gives an estimate of the variance that tends to be low. The way to see this is to realize that each ##(X_i - \bar X)^2## is a little small because the value of ##X_i## has drawn ##\bar X## toward it, which wouldn't happen with ##(X_i-\mu)^2##.
3) ##\sum {(X_i-\bar X)^2}/(n-1)## does not need the knowledge of ##\mu## and it exactly corrects for the problem of ##\sum {(X_i-\bar X)^2}/n## tending to be too small. It is unbiased.
I would say that lots of sophisticated statistical tests should be run to check. Unfortunately, a lot of time people just plug in their data and look for a p-value.
Likes fog37
Thank you!
You may choose any confidence level you like. 99.9999% is quite possible.
Likes fog37
Or you can just construct the confidence interval ##(-\infty,\infty)## and get 100% confidence.
Likes fog37 and FactChecker
Yes, there is a fundamental problem in conceptualizing statistics and probability theory. We seek to develop mathematics in careful way so that its theorems are true - i.e. certainly true. So what happens when the subject matter of the mathematics is supposed to represent something that is uncertain?
The bottom line is that is that probability theory (when interpreted as uncertainty about whether something happens) only tells you things abut probabilities. It has no theorems that tell you that something is certain to happen. (The closest you get to that type of result are theorems about the limits of probabilities approaching 1.) The theorems of probability theory have the form: if the probability of something is such-and-such then the probability of this other thing is so-and-so. You can see this pattern in sampling statistics. A sample statistic of a random variable is itself a random variable, so the sample statistic has a distribution. The distribution of sample statistic has its own sample statistics and they have their own distributions - etc.
So applying probability theory depends on the science of whatever subject you are applying it too. There are no theorems in probability theory that gurantee the correctness of using it in a particular way in all possible practical situations. Things like the familiar numbers used for "statistical significance" are not consequences of mathematical theorems. They've come into use because they've been empirically useful in many situations.
Likes fog37, jim mcnamara and FactChecker
I would like to point out that it is true of all applied mathematics. Physics was all applied mathematics until string theory emerged.
The challenge of General Relativity wasn't the math, it lay in convincing that the mathematics corresponded to the real world.
Likes fog37 and Stephen Tashi
fog37 said:
TL;DR Summary: Unbiasdness of estimates
Hello (again).
Thank you!
A slightly different comment here. From your post, this
"we want out estimators to be unbiased so the expectation value of the mean "tends" to the actual population mean."
confuses two things. When we talk about an estimator being unbiased we mean that when the expected value of the estimator is taken that expected value is the parameter you're estimating, and this is true regardless of the sample size: it is a property of the "structure" of the estimator, not any particular sample size.
Saying "the expectation value of the mean "tends" to the actual population mean" isn't the same thing. This is "asymptotically unbiased": here the estimator may not be unbiased but the sequence of expectations of the estimator converges (as n tends to infinity) to the target parameter. This is an asymptotic property, a limiting property.
I'll also comment that, occasionally, we're willing to accept using an estimator with a small amount of bias if its standard error is significantly lower than the standard error of an unbiased estimator.
FAQ: Is Unbiasedness in Estimation Truly Reflective of Population Parameters?
1. What does unbiasedness in estimation mean?
Unbiasedness in estimation refers to a property of an estimator where the expected value of the estimator equals the true value of the population parameter it aims to estimate. In other words, if we were to take many samples and compute the estimator for each sample, the average of those estimates would converge to the actual population parameter.
2. Why is unbiasedness important in statistics?
Unbiasedness is important because it ensures that the estimator does not systematically overestimate or underestimate the population parameter. This property allows researchers to have confidence that their estimates are accurate on average, which is crucial for making valid inferences and decisions based on statistical analysis.
3. Can an estimator be unbiased but still not reflective of the population parameter?
Yes, an estimator can be unbiased but not reflective of the population parameter in terms of variability or precision. For instance, an unbiased estimator may have a large variance, meaning that while the average of the estimates is correct, individual estimates may vary widely and lead to unreliable conclusions about the population parameter.
4. What are some examples of unbiased estimators?
Common examples of unbiased estimators include the sample mean as an estimator for the population mean and the sample proportion as an estimator for the population proportion. Both of these estimators have the property that their expected values equal the true population parameters they are estimating.
5. How can we assess the performance of an estimator beyond unbiasedness?
Beyond unbiasedness, the performance of an estimator can be assessed using several criteria, including efficiency (the variance of the estimator), consistency (whether the estimator converges to the true parameter as the sample size increases), and sufficiency (whether the estimator captures all relevant information from the data). These criteria help provide a more comprehensive evaluation of how well an estimator performs in practice.
