Unbised estimator of Binomial Distribution
In summary, the conversation discusses finding an unbiased estimator of p^m for a given binomial distribution. The participants mention using induction and constructing a random variable, but there is some confusion regarding the value of m and how to sum the variable. Ultimately, the discussion concludes that Y = X_1...X_m is an unbiased estimator for p^m.
leon1127
486
[SOLVED] unbised estimator of Binomial Distribution
I have no idea how to find such an estimator
Suppose[tex]X_1, ..., X_n \sim Bern(p)
[/tex]
find an unbiased estimator of [tex]p^m, for m < n[/tex]
Induction on m was a nasty mess that should not be expected. The power of m causes some problem when I try to go from the definition of expectation. Any one have some hint?
Statistic u is unbiased if E = p^m. Suppose m = 2. To find u, you count all sequences that have two successes in a row, then express them as a ratio of the total number of trials. Would that satisfy E = p^2?
I approached in a similar way.
It is clear that [tex] Y = X_1...X_m [/tex] is unbiased for p^m. I was asked to find an unbiased estimator that is a function of sample total. Thus I construct a R.V which
[tex] Z(T) = 1 for T = 26; 0 elsewhere[/tex]
I might have to normalise Z so that it is the same as Y. However I don't know how to sum it.
Where did 26 come from?
If you look at my previous post you will see that it is a function of the sample total.
it is not 26, it should be m...
Very well, my previous post applies.
k gotcha thx
FAQ: Unbised estimator of Binomial Distribution
What is an unbiased estimator of Binomial Distribution?
An unbiased estimator of Binomial Distribution is a statistical method used to estimate the probability of success in a series of independent trials, where the outcome of each trial is either a success or a failure. It is unbiased because, on average, the estimated probability of success is equal to the true probability of success.
How is an unbiased estimator of Binomial Distribution calculated?
The unbiased estimator of Binomial Distribution is calculated by dividing the number of successes by the total number of trials. This is known as the sample proportion and is represented by p-hat. The formula for p-hat is p-hat = x/n, where x is the number of successes and n is the total number of trials.
What are the assumptions of using an unbiased estimator of Binomial Distribution?
The assumptions of using an unbiased estimator of Binomial Distribution are that the trials are independent, the probability of success remains constant for each trial, and there are only two possible outcomes for each trial (success or failure).
Why is it important to use an unbiased estimator of Binomial Distribution?
Using an unbiased estimator of Binomial Distribution is important because it allows for accurate estimation of the probability of success in a series of trials. This can be useful in making decisions, conducting research, and analyzing data in various fields such as psychology, economics, and biology.
What are some examples of when an unbiased estimator of Binomial Distribution is used?
An unbiased estimator of Binomial Distribution is commonly used in situations where there are two possible outcomes, such as flipping a coin, conducting a survey with yes/no questions, or testing the effectiveness of a new medication. It is also used in quality control processes to estimate the proportion of defective products in a sample.
10K
