What is the Uncertainty in the Total Weight of a Collection of Similar Items?
In summary, the article discusses the concept of uncertainty in measuring the total weight of a collection of similar items. It emphasizes the importance of understanding the sources of variability, such as individual item weight differences and measurement errors. The article outlines methods to quantify this uncertainty, including statistical approaches and the propagation of measurement errors, ultimately highlighting that accurately assessing uncertainty is crucial for reliable weight estimations in various applications.
JT Smith
419
591
TL;DR Summary
Determine uncertainty in total weight of N different objects weighed separately (NOT homework)
Not a homework assignment. Just what must be a solved problem that I'm embarrassed I don't know how look up or figure out on my own.
I want to know the total weight of a collection of N items. They are all similar but of different, unknown weights. My scale has a known accuracy of ±U units. If I weigh 1 object I can say that it's weight is as measured, ±U. So what can I say about the uncertainty of the total weight of N objects?
EDIT: Each item weighed separately.
How many items can you place on the scales at the one time?
JT Smith said:
TL;DR Summary: Determine uncertainty in total weight of N different objects weighed separately (NOT homework)
You can use the propagation of uncertainty to determine this. In this situation, the variance of the total weight is the sum of the variances. And since each measurement has the same variance we get $$U_{total}=\sqrt{N} U$$
Likes russ_watters
One at a time. Sorry, I left that important fact out of the description.
Thank you, that's what I wanted to know.
I mistakenly thought that rule only applied when repeatedly measuring the same thing.
You are welcome. It applies any time you are adding up a bunch of measurements each with the same uncertainty.
Likes russ_watters
What does that mean?
If it always reads a half-gram high, this formula will not be right.
Likes jbriggs444
If it's always a half-gram high, it doesn't have "a known accuracy of ±U", so the formula does not apply.
What does it mean when a scale has a specification of a certain precision? I take it to mean that, ideally at least, that a large number of measurements would generate a symmetric distribution, around the mean value, that has a width corresponding to the precision. And by width I mean a large percentage of the measurements (95%?) would fall within. Maybe this isn't exactly right but I think I have the basic idea.
In general it's probably a very complicated question. I just wanted a basic approach to extending the uncertainty because the worst-case scenario, where every measurement is at maximum uncertainty in the same direction, isn't very realistic -- provided the error is truly random. If there is some sort of systematic bias then it's a different question.
That is correct. That is why I wanted you to think about it.
If you take two meter sticks and place them side by side, they may differ by 1 or even 2 mm. Obviously, they can't both be right. So the idea "distribution around the mean value: is non-trivial. Your single number represents two concepts - "how wide is this distribution" and 'how well is it centered around the true value".
Usually the reported specification would be one standard deviation. Hopefully the documentation is clear, eg by using the term “standard uncertainty” or “standard deviation”. But if it is ambiguous then assume it is a standard deviation rather than a 95% confidence interval.
Likes Vanadium 50
I disagree. An unknown systematic error may still be known to be bounded by ##\pm U##.
Likes Vanadium 50 and Dale
That's why I said "accurate" instead of "precise". I wanted to convey the message that the scale was reporting a range of values centered around the true value.
I don't know what is standard for specifications. I don't own any expensive laboratory balances. The consumer grade scales I have used usually just specify precision and linearity. I suppose I could carefully test my scale and figure out the confidence level. A real scale may be less precise at higher weights, which is why I said that the items in question were of similar weight.
But I never meant for this to go very deep. My question was simple and has been answered. That's not to say you guys can't take it further though.
Likes Nugatory and Dale
FAQ: What is the Uncertainty in the Total Weight of a Collection of Similar Items?
What does "uncertainty" mean in the context of measuring the total weight of similar items?
Uncertainty in this context refers to the range within which the true total weight of the collection of items is expected to lie. It accounts for possible variations and errors in the measurement process, ensuring that the reported weight is accompanied by an indication of its reliability.
How do you calculate the uncertainty in the total weight of a collection of similar items?
To calculate the uncertainty in the total weight, you typically need to know the individual uncertainties of each item's weight measurement. If the uncertainties are independent and random, the total uncertainty can be found by combining the individual uncertainties in quadrature, which means taking the square root of the sum of the squares of the individual uncertainties.
Why is it important to consider uncertainty when measuring the total weight of similar items?
Considering uncertainty is crucial because it provides a more accurate and realistic representation of the measurement. It helps in understanding the reliability and precision of the measurement, which is essential for scientific experiments, quality control in manufacturing, and various other applications where precise measurements are critical.
Can the uncertainty of individual items be different, and how does that affect the total uncertainty?
Yes, the uncertainty of individual items can be different. When calculating the total uncertainty, each item's uncertainty must be taken into account. If the uncertainties vary, each one is squared, summed, and then the square root of this sum is taken to find the total uncertainty. This method ensures that larger uncertainties have a proportionately greater impact on the total uncertainty.
What tools or instruments can be used to minimize the uncertainty in weight measurements?
To minimize uncertainty in weight measurements, high-precision scales or balances should be used. Additionally, ensuring that the measurement environment is controlled (e.g., stable temperature, no air currents) and calibrating the instruments regularly can help reduce measurement errors. Using standardized procedures and taking multiple measurements to average out random errors can also improve accuracy.
11K
20K
