Uncertainty momentum position velocity
The discussion revolves around calculating the minimum uncertainty in the position of an electron given its velocity and uncertainty in velocity. The relevant equation used is delta(x) * delta(P) >= hbar/2, where delta(P) is derived from the uncertainty in velocity multiplied by the mass of the electron. The participant confirms that they can compute delta(x) without needing the specific position or velocity values. The response emphasizes careful notation in calculations to avoid confusion. The conclusion is that the necessary information for the calculation is sufficient without specific values for position and velocity.
jackxxny
I have a dilemma. My problem states that an electron that is in position 2.34 nm along the x axis, travels along the x-axis with a certain speed (A) and a with the uncertainty in the velocity (B). I am asked to calculate the minimum uncertainty in the position.
I know
delta(x)*delta(P)>= hbar/2
delta(P)= delta(v)*(mass electron)
for delta(v) I'm going to use the B
I have done this
delta (x) = (hbar)/2*(delta(v))*(mass electron)
my question is, i don't need the position and the velocity then
jackxxny said:
I have done this
Careful with parentheses--it's hard to tell if you are multiplying or dividing by delta(P).
That's right--you don't need that information.
  • · Replies 21 ·
  • · Replies 16 ·
