Uncertainty of Average Acceleration
In summary, σ_{a,avg} = \sqrt{\sum^{i=1}_{n}}. The Attempt at a Solution attempted to find the uncertainty for a by using the basic addition formula for uncertainties and the multiplication formula for products of uncertainties. However, they are not sure if this is correct.
pry_or
You have determined the acceleration [itex]a_{i}[/itex] of an object in free fall for i = 1 to n different time intervals. What is the algebraic expression for the uncertainty [itex]σ_{a,avg}[/itex] in [itex]a_{avg}[/itex]? (Use any variable or symbol stated above as necessary.)
The answer box is formatted as such: [itex]σ_{a,avg}[/itex] = [itex]\sqrt{\sum^{i=1}_{n}}[/itex]
and I have to fill in the space after the summation under the square root.
No variables or symbols were specifically given for the problem outside of the ones in the question, but I had written the formula for average acceleration previously (in the relevant equations section) that may have variables I can use.
[itex]a_{avg}[/itex] = [itex]\frac{v_{23} - v_{12}}{t_{23} - t_{12}}[/itex]
I honestly have no clue where to begin. I don't really have much knowledge of uncertainty calculations and so I am pretty lost here. I tried one method first that I realized is incorrect.
Any help would be extremely appreciated.
Do you know the definition of the standard deviation [itex]\sigma[/itex] or the variance [itex]\sigma^2[/itex]? It seems unusual to be asked such a question without at least some reference to the definition in the text.
Yeah, I know the definitions. They are given to me. I can usually apply the formulas, but I am not sure how to do it for this question.
After some thinking, I believe I could write the formula a = Δv/Δt, since I can calculate [itex]σ_{Δv}[/itex] and [itex]σ_{Δt}[/itex] using basic addition. So [itex]σ_{Δv} = σ_{v_{12}} + σ_{v_{23}}[/itex] and [itex]σ_{Δt} = σ_{t_{12}} + σ_{t_{23}}[/itex]. So I can then apply it to the multiplication formula to find the uncertainty for a. Using the formula given in the text, I would think the uncertainty for the basic formula I gave in my original post would be
[itex]σ_{a_{avg}} = a_{avg}\sqrt{(\frac{σ_{Δv}}{Δv})^{2} + (\frac{-σ_{Δt}}{Δt})^{2}}[/itex]
I don't know whether this is correct or not. And if it is, I am stuck trying to figure out how to use the summation that is given in the answer area.
For ease of reference, here is the answer area:
Yeah, you're kind of going off into space here. This problem isn't about dealing with uncertainties from other variables, just from the data set that you have.
Something like this formula should look familiar:
[tex]\sigma_x^2 = \sum_i (x_i - \bar x)^2/N[/tex]
It's been about 2.5 years since I did real standard deviation or variance calculations. The two formulas given in the text are both about uncertainties from other variables. One is for addition of uncertainties and one is for products of uncertainties. And in previous assignments, all the calculations we did dealt with these formulas. This is what is throwing me off because the book doesn't include anything regarding the answer formula. And as such, I do not fully understand your formula. I believe it looks familiar from my previous math experience though.
So I am guessing [itex]x_{i}[/itex] would be [itex]a_{i}[/itex] and [itex]/bar{x}[/itex] would be [itex]a_{avg}[/itex]?
Yes. You might also see [itex]\sigma^2_x = \langle x^2 \rangle - \langle x \rangle^2[/itex]. Also note that I neglected a factor of [itex]N[/itex] which is necessary to to get it right.
Alright, this is the answer after all. Even though there is not a single reference to this in the book! Thanks very much for your help!
Related to Uncertainty of Average Acceleration
What is uncertainty of average acceleration?
The uncertainty of average acceleration is a measure of the potential error or variation in the calculated average acceleration of an object over a certain period of time. It takes into account the uncertainties in the measurements used to calculate the average acceleration.
How is uncertainty of average acceleration calculated?
Uncertainty of average acceleration is calculated by taking the square root of the sum of the squares of the individual uncertainties in the measurements used to calculate the average acceleration. This is known as the root mean square (RMS) method.
Why is uncertainty of average acceleration important?
Uncertainty of average acceleration is important because it helps to determine the reliability and accuracy of experimental results. It allows scientists to understand the potential error or variation in their measurements and make more informed conclusions about their data.
How can uncertainty of average acceleration be reduced?
Uncertainty of average acceleration can be reduced by using more precise and accurate measurement tools, increasing the number of measurements taken, and conducting the experiment multiple times to improve the reliability of the data.
What are the units of uncertainty of average acceleration?
The units of uncertainty of average acceleration are the same as the units of average acceleration, which is typically meters per second squared (m/s²) in the SI system. This is because uncertainty is a measure of variation and not a physical quantity that can be measured in its own right.
10K
