Uncertainty of coherent states of QHO
In summary, the uncertainty in x and p of the coherent state |z> = e^{-|z|^2/2} \sum\frac{z^{n}}{\sqrt{n!}} |n> can be found by finding the expected value of x and using the relation between <x> and uncertainty. The ladder operator definition of x can be used, but there may be nonvanishing terms in the sum that require evaluation using \langle n | n' \rangle = \delta_{nn'}.
BiotFartLaw
What is the uncertainty in x and p of the coherent state
[itex]|z> = e^{-|z|^2/2} \sum\frac{z^{n}}{\sqrt{n!}} |n>[/itex]
This seems pretty straight-forward to me. You just find the expected value of (let's say) x:
[itex]<z|x|z>[/itex], and use the relation between <x> and uncertainty. And you use the ladder operator definition of x:
[itex] \hat{x}= \sqrt{ \frac{\hbar}{m \omega}}( \hat{a} + \hat{a}^{+})[/itex]
When I work out the math using the fact that [itex] \hat{a}|n> = \sqrt{n}|n-1>[/itex] and [itex] \hat{a^{+}}|n> = \sqrt{n+1}|n+1>[/itex]
I run in to:
A*<n-1|n> + B*<n|n+1>
(Where A and B are summations).
So my question is: what are <n-1|n> and <n|n+1>? They are energy eigenkets for the QHO But are they orthogonal? And if they are...what do? (Since everything then goes to 0). And if they aren't, what is their inner product?
Thanks.
I run in to:
Thanks.
Indeed [itex]\langle n | n\pm 1\rangle =0[/itex]. However, you've oversimplified things. What you should really find is an expression like
[tex] \sum_{n, n'} \left( A_{nn'} \langle n' | n -1 \rangle + B_{nn'} \langle n' | n +1 \rangle \right). [/tex]
There are nonvanishing terms appearing in the sum which you can evaluate using [itex]\langle n | n' \rangle = \delta_{nn'}.[/itex]
FAQ: Uncertainty of coherent states of QHO
What is the uncertainty principle in quantum mechanics?
The uncertainty principle in quantum mechanics states that there is a fundamental limit to the precision with which certain pairs of physical properties of a particle can be known simultaneously. This means that the more precisely one property is known, the less precisely the other can be known.
How does the uncertainty principle relate to coherent states of the quantum harmonic oscillator (QHO)?
The uncertainty principle applies to all physical systems, including the QHO. In the case of coherent states, the uncertainty principle dictates that the uncertainty in the position and momentum of the particle must have a minimum value. This minimum value is known as the zero-point uncertainty and is a fundamental property of the QHO.
What is the significance of the zero-point uncertainty in QHO coherent states?
The zero-point uncertainty is significant because it sets a lower limit on the precision with which the position and momentum of a particle can be known. This means that even in the most ideal conditions, there will always be a certain amount of uncertainty in the measurement of these properties for a QHO coherent state.
Can the uncertainty of coherent states of QHO be reduced?
No, the uncertainty of coherent states of QHO cannot be reduced. This is because the zero-point uncertainty is a fundamental property of the QHO and is a result of the quantum nature of the system. Any attempt to reduce this uncertainty would violate the laws of quantum mechanics.
How does the uncertainty of coherent states of QHO affect the behavior of the system?
The uncertainty of coherent states of QHO affects the behavior of the system in that it limits the precision with which the position and momentum of the particle can be known. This uncertainty also affects the dynamics of the system, as the particle's position and momentum will fluctuate around the zero-point uncertainty value, leading to quantum fluctuations in the system's energy and other properties.
