Uncertainty of pendulum period and pendulum length
In summary: Note that the oscillation period for a pendulum depends on the amplitude, so you want to do each measurement starting from the same -- small! -- amplitude.In summary, for calculating the uncertainty of time taken for 1 oscillation, there are two methods that can be used: estimating sources of error for one measurement or using the standard error of the mean for multiple measurements. It is important to make sure the measurement is done at a consistent amplitude.
dobbygenius
30
what is the uncertainty of time taken?
I'm doing a lab report where I manually measure the time taken for a bifilar pendulum to do 10 oscillations. Is there a rule or a method that I should follow to calculate its uncertainty? Or is the uncertainty just an estimation of human reaction time and judgment?
I also need to know the uncertainty of 1/length. First I measured the bifilar pendulum with a ruler of 0.001 m increment so the length uncertainty is 0.001/2=0.0005 m. However, in my investigation, I need to know the uncertainty of 1/L where L is length. Is there also a rule to calculate the uncertainty of 1/L? Or does it follow the uncertainty of length itself (0.0005)?
Thank you so much for any help 😆
If the uncertainty in length is << L, you can assume that the relative uncertainty in 1/L is the same as the relative uncertainty in L, i.e.
u(L)/L = u(1/L)/(1/L)
Thus u(1/L) = (1/L)*u(L)/L = u(L)/L2.
Likes dobbygenius
thank you so much!
You could repeat the measurement a number of times and calculate an estimate of the standard deviation from the sample. See e.g. 'Sample standard deviation' here .
This only works if you don't get the same result for all measurements :smile:
Sure ...
But you want to be clear on what exactly you are measuring. What you want is probably the ##L## in the formula. The distance from the suspension point to the center of mass of the pendulum (or some other point perhaps ?). That is two readings on your ruler (which itself must be reliably calibrated at the same temperature as the temperature at the time of your measurement).
Draw an end view of your setup and think about this ##L##
This is not to scare you off but to encourage you to consider details and assign some (or no) weight to them. :smile:
Likes dobbygenius
dobbygenius said:
Homework Statement:: what is the uncertainty of time taken?
Relevant Equations:: -
There are two methods I see used.
With only one measurement, you would estimate the sources of error; in this case, accuracy of timing, accuracy of count (but I'm sure you can ignore the second).
For many samples, you would use the "standard error of the mean". This is different from the "Sample standard deviation". In particular, it diminishes as the sample size increases, as should be expected.
See https://www.investopedia.com/ask/an...andard-error-means-and-standard-deviation.asp.
In principle, there should be a method which melds the two so that it works for all sample sizes, but I have never found one.
Likes dobbygenius
Sure ...
I see, thankyou so much again!
I got the uncertainty of the average time taken for 10 oscillations to be 0.9%. Now I need to know the uncertainty of the time taken for 1 oscillation, is there another method to calculate the uncertainty of this?
I see, thankyou!
If the number ten is without error, the relative error for one oscillation is the same as the relative error for ten oscillations.
If you are familiar with differentiation:$$\Delta f(x) \approx {\partial f\over\partial x}\Delta x \Rightarrow \Delta 10x \approx 10\Delta x\Rightarrow {\Delta 10x \over 10x} \approx {\Delta x\over x}$$ (actually, squares or absolute values; see here and examples)
FAQ: Uncertainty of pendulum period and pendulum length
What is the relationship between pendulum period and pendulum length?
The period of a pendulum is directly proportional to the square root of its length. This means that as the length of the pendulum increases, the period also increases.
How does the uncertainty of pendulum length affect the uncertainty of pendulum period?
The uncertainty of pendulum length can directly affect the uncertainty of pendulum period. If the length measurement is not precise, it can lead to a larger uncertainty in the period calculation.
What are some sources of uncertainty in measuring pendulum length?
Some sources of uncertainty in measuring pendulum length include human error in reading the measurement, variations in the pendulum's position due to air resistance, and slight differences in the center of mass of the pendulum.
How can we reduce the uncertainty of pendulum period and pendulum length measurements?
To reduce the uncertainty of pendulum period and length measurements, it is important to use precise measuring tools, take multiple measurements and calculate an average, and minimize any external factors that may affect the pendulum's movement, such as air resistance.
What is the significance of understanding the uncertainty of pendulum period and pendulum length?
Understanding the uncertainty of pendulum period and length is crucial in conducting accurate experiments and making precise calculations in physics. It also helps in identifying potential sources of error and improving the accuracy of future experiments.
