Uncertainty principle and double-slit interference?
In summary: Yes, the photons have a momentum as well. In fact, the photons in the double slit experiment always have a certain momentum, even if we cannot measure it. This is because the wave function describes the probability amplitudes of a photon, not the probability itself. So even though we cannot see the photon's momentum, it still has it.
  • #36
Yes, that's all true. Indeed, I would say that "what happened to the particle" is not even a scientific question, unless you make it part of the experimental setup to answer it-- in which case it is now a different question because it pertains to a different situation. If you can answer it in some systems that give all the same results for the measurables of similar systems not set up to answer that question, then you have a basis for giving a more general answer. But oftentimes, you will not get the same results when you do that (as with asking which slit the photon went through). Fortunately, quantum mechanics tells you when this is the case, and there is never a need to leave the Copenhagen interpretation to get that answer.
  • #37
peter0302 said:
We can get the pattern only when we have no idea, even in principle, which slit the photon went through.
Exactly
Mathematically, it's _equivalent_ to saying the photon went through both slits, but you whether it _really_ went through both is a matter of interpretation.
On this I agree with you. Think that I believe the photon don't go through any of them! :smile:
(It was not irony, I really believe this).
  • #38
Haha. Well, that's why the double slit continues to be "the only mystery" because there are so many different ways of looking at it, all of which lead to the same result, that 83 years later we still don't have agreement.
  • #39
It hasn't been heralded as the greatest experiment of the 20th century for nothing. There can be no agreement without measurement and no agreement with it? We're kind of at an impasse. Even if we measure where the wave is not, we still have the same problems.
  • #40
I agree with you that What happened to the particle before it's detected is not something on which there is universal agreement. But the double-slit experiment is so weird. I need to think of it deeply. Thank you for your discussion.
If you have some good ideas on it, welcome to contact me. My email address is xylai2000@gmail.com . Thank you.
peter0302 said:
The _possibility_ of passing through either slit is what creates the interference pattern. When you close one slit, you remove that possibility. When you peek behind the slits, you remove that possibility.
You don't have to believe that it _actually_ passed through both, for one reason because no one can agree on what "actual" or "really" mean. All we can say is that possibilities influence the wave function, and the wave function influences where you'll end up finding the particle. What happened to the particle before it's detected is not something on which there is universal agreement. Quite the contrary.
  • #41
Schrodinger's Dog said:
Just to be sure are you talking about the double slit quantum eraser experiment?
You would it is called the http://www.sciam.com/article.cfm?id=how-can-a-single-photon-p" which produces interference patterns when you fire one photon at a time.
Hi all,
I am searching for "quantum version conjugate of double slit" . Before photons reach the double slit, their wave function is delta function and after the double slit, on the screen, we have an interference pattern. The question is: Is there any mechanism to convert this interference pattern( this complex wave function of photons) to delta function as they had before double slit? It means the conjugate of double slit.
I appreciate it if one can answer this question.
