Uncertainty Principle and the size of an atom
In summary, the uncertainty principle states that the momentum of an electron is greater than the momentum of a proton, due to the uncertainty in their speeds.
nobahar
497
Hey,
Sorry, but I have a qustion on the uncertainty principle to join the many others.
Just reading a book on physics, and its says that, as a result of the Heisenberg uncertainty principle, if the proton and electron were confined to the same volume of space, the electron would be traveling about 2,000 times faster, as the proton is 2,000 times bigger. How is this a consequence of the uncertainty principle? It must entail the momentum and the position, but I don't see how.
Thanks in advance for your responses.
m (delta(v))(delta(x)) greater than h, says it all...
First, it is incorrect to say that the electron will be traveling 2000 times faster; the correct statement would be that the uncertainty in the electron's speed is about 2000 times greater than the the uncertainty in the proton's speed.
By confining the proton and the electron to the same volume, you are essentially saying that the uncertainty in position is the same for both particles (i.e. [itex]\Delta x_{\text{electron}}=\Delta x_{\text{proton}}[/itex] )
So, if you assume that [itex]\Delta x_e\Delta p_e=\frac{\hbar}{2}[/itex] and [itex]\Delta x_p\Delta p_p=\frac{\hbar}{2}[/itex] then you have:
[tex]\Delta x_e\Delta p_e=\Delta x_p\Delta p_p[/tex]
[tex]\implies \Delta p_{\text{electron}}=\Delta p_{\text{proton}}[/tex]
Then you simply use the fact that [itex]\Delta p_e=m_e\Delta v_e[/itex] and that [itex]\Delta p_p=m_p\Delta v_p[/itex] (since you presumably know the masses of the electron and proton exactly, the uncertainty in their momenta is due entirely to the uncertainty in their speeds) and you get
[tex]\Delta v_e =\frac{m_p}{m_e} \Delta v_p \approx 2000\Delta v_p[/tex]
gabba> you mean v subscript p in your last line of working
Yes, thank you. I've edited my post.
Thanks Gabba,
That's extremely clear and awesome.
Thanks!
FAQ: Uncertainty Principle and the size of an atom
What is the Uncertainty Principle?
The Uncertainty Principle, also known as Heisenberg's Uncertainty Principle, is a fundamental concept in quantum mechanics that states that it is impossible to know the exact position and momentum of a particle at the same time with complete accuracy.
How does the Uncertainty Principle relate to the size of an atom?
The Uncertainty Principle affects the size of an atom because it sets a limit on how precisely we can measure the position of an electron within an atom. Since the electron's position and momentum are constantly changing, it is impossible to determine its exact location at any given moment. This uncertainty in the electron's position contributes to the overall size and shape of the atom.
Why is the Uncertainty Principle important in science?
The Uncertainty Principle is important because it challenges our traditional understanding of physics and the ability to make precise measurements. It also plays a crucial role in quantum mechanics and our understanding of the behavior of subatomic particles.
Can the Uncertainty Principle be violated?
No, the Uncertainty Principle is a fundamental principle in quantum mechanics and cannot be violated. It is a natural limitation inherent in the behavior of particles at the quantum level.
How does the Uncertainty Principle affect our everyday lives?
The Uncertainty Principle may not have a direct impact on our everyday lives, but it has led to many technological advancements, such as the development of semiconductors and lasers, which are essential to modern technology. It also helps us understand the behavior of matter at a fundamental level, leading to advancements in fields such as medicine and materials science.
