I Uncertainty principle##\Delta H\Delta Q##, where Q is time-independent
Foracle
TL;DR Summary
Why is ##\Delta H\Delta Q \ge |\frac{ħ}{2}##d<Q>/dt##|##
Let Q be a time-independent operator.
##[H,Q] = iħ[\frac{d}{dt},Q]##
Since Q is time-independent, ##[H,Q]=0##
And from the uncertainty principle :
##\Delta H\Delta Q \ge |<\Psi|\frac{1}{2i}[H,Q]|\Psi>|##
From ##[H,Q] = 0##, I concluded that ##\Delta H\Delta Q \ge 0##
But by evaluating d<Q>/dt, it can be found that ##\Delta H\Delta Q \ge |\frac{ħ}{2}##d<Q>/dt##|##
I know that the right answer is the latter, but I just want to know why ##\Delta H\Delta Q \ge 0## is wrong.
You go wrong when you equate the Hamiltonian with the time derivative. Your identification implies there is no difference between the Hamiltonians describing different systems or the time-evolution of the wavefunctions for those systems.
I read Hanbury Brown and Twiss's experiment is using one beam but split into two to test their correlation. It said the traditional correlation test were using two beams........ This confused me, sorry. All the correlation tests I learnt such as Stern-Gerlash are using one beam? (Sorry if I am wrong) I was also told traditional interferometers are concerning about amplitude but Hanbury Brown and Twiss were concerning about intensity? Isn't the square of amplitude is the intensity? Please...
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
