Uncertainty Pulsar PSR 1937+21
In summary, The book Fundamentals of Physics by Halliday discusses time standards based on atomic clocks and a promising second standard based on pulsars. Pulsars are rotating neutron stars that emit highly stable radio beacons. The example given, Pulsar PSR 1937+21, rotates once every 1.55780644887275 ±3 ms. Using this information, the solutions for part A and B of problem #16 in the first chapter are 3.88×10^8 rotations in 7.00 days and 1.56×10^3 seconds, respectively. The associated uncertainty for part C is ±30 ps. The solution was found using the well-known formula for uncertainty on a function, which
truthfinder
24
I feel stupid for asking this, but the book I'm working through doesn't explain it at all, and I want to make sure I am correct.
The book is Fundamentals of Physics, by Halliday. This is problem #16 after the first chapter.
Time standards are now based on atomic clocks.
A promising second standard is based on pulsars, which are rotating neutron stars.
Some rotate at a rate that is highly stable, sending out a radio beacon that sweeps briefly across Earth once with each rotation, like a lighthouse beacon.
Pulsar PSR 1937+21 is an example. It rotates once every 1.55780644887275 ±3 ms, where the trailing ±3 indicates the uncertainty in the last decimal place. It does not mean +-3 ms.
A. How many rotations does PSR 1937+21 make in 7.00 days?
B. How much time does the pulsar take to rotate exactly 1000000 times.
C. What is the associated uncertainty?
My solutions for A and B (please forgive me if my tex isn't very good):
A:
Convert 7 days to ms
[tex]7 days \times \frac{24 hr}{1 day} \times \frac{60 min}{1 hr} \times \frac{60 s}{1 min} \times \frac{1000 ms}{1 s} = 604800000 ms[/tex]
[tex]\frac{604800000 ms}{1.55780644887275 ms} = 3.88\times 10^8 rotations[/tex]
B:
[tex]1.55780644887275 ms \times 1000000 = 1.56E6 ms[/tex]
[tex]1.56\times 10^6 ms \times \frac{1 s}{1000 ms} = 1.56\times 10^3 s[/tex]
C:
This is the part I am not sure about.
My logic is that if the last digit is ±3, that is 14 decimal places. So I took:
[tex]3\times 10^{-14} \times 1000000[/tex]
That gives 3e-8 ms
I wanted to simplify this a bit, so I converted it to seconds:
[tex]\frac{3\times 10^{-8}}{1000} = 3\times 10^{-11}[/tex]
Simplifying it to simpler units:
[tex]3\times 10^{-11} \times 1\times 10^12 = 30 ps[/tex]
Therefore my answer is ±30 ps.
But seriously, the book never mentions uncertainty, so I did the first thing that was logical to me. It seems to have the tendency to ask about things it doesn't discuss, though so far it has only been various common formulas.
Well the well-known formula for the uncertainty on a function f(x1,x2,...xn), where each x has a known uncertainty is:
[tex]\sigma^2_f = \sum_{i=1}^{i=n}(\frac{\partial f}{\partial x_i})^2\sigma^2_{x_i}[/tex]
I'm sure you can apply this to your problem.
I'm glad you are so confident. I am not. I should note that this is an introductory physics course in college, usually taken by freshmen, and is the first chapter of the book, so I doubt such an equation would be used yet?
all it is is that one rotation's time has the given uncertainty. if that rotation is repeated 1000000 times, wouldn't the uncertainty be multiplied by the same? perhaps not, but the equation seems rather complicated for the problem.
It's a good equation, but I don't know what sigma is, nor F, not to mention I don't have a function to which to apply it...
Thanks for the reply, though.
Well the equation is supposed to be completely general. Sigma represents uncertainties, and f is the function on which you know the uncertainty. Here in this case, sigma = 3 * 10^-14s, this is the uncertainty on the variable P (P for period). f is given by f = 1000000P. In this case, yes, the the derived uncertainty is just 1000000 times the uncertainty on P (as one can check, if they wish, by using the formula I gave). In this case, the formula need not be applied and using your intuition is fine.
However, suppose you wanted to find the uncertainty on your answer for part b. To get the correct answer, you would have to use the formula I gave.
I think it is a worthwile formula to be familiar with, especially if you plan on later doing any labs in physics.
Thanks. Well, do I notice correctly there is a partial derivative in there, assuming \partial means partial derivative? I've only gone through calc 1 so far, and we didn't cover anything like that. When I can, I'd love to figure out how to calculate this, though.
Calculating partial derivatives is really very simple. You don't need any knowledge passed Cal1 to do so. Simply differentiate with respect to one variable, while holding the others constant. For example, let [itex]f(x,y) = x^2y[/itex]. Then
[tex]\frac{\partial f}{\partial x} = 2xy[/tex]
and
[tex]\frac{\partial f}{\partial y} = x^2[/tex].
truthfinder said:
C:
That gives 3e-8 ms
You did part C just right. That's all they wanted.
Related to Uncertainty Pulsar PSR 1937+21
1. What is a pulsar and how does it relate to PSR 1937+21?
A pulsar is a type of neutron star that emits regular pulses of electromagnetic radiation. PSR 1937+21 is a specific pulsar located in the constellation Vulpecula.
2. Why is PSR 1937+21 known as the "Uncertainty Pulsar"?
PSR 1937+21 is known as the "Uncertainty Pulsar" because its pulses arrive at irregular intervals, making it difficult to predict when the next pulse will occur.
3. How was PSR 1937+21 discovered?
PSR 1937+21 was discovered in 1982 by astronomers using the Arecibo radio telescope in Puerto Rico. They noticed its unusual pulse arrival times and determined it to be a pulsar.
4. What makes PSR 1937+21 important to scientists?
PSR 1937+21 is important to scientists because it is the fastest-spinning pulsar known, with a rotation period of just 1.56 milliseconds. Its extreme properties provide valuable insights into the nature of neutron stars and the laws of physics.
5. How does the uncertainty of PSR 1937+21 affect its usefulness as a navigation tool?
The uncertainty of PSR 1937+21 makes it unsuitable as a navigation tool because its pulses arrive at unpredictable intervals. This makes it difficult to accurately determine a location based on its signals. Other pulsars with more regular pulses are used for navigation purposes instead.
13K
