Uncertainty significant digits
In summary: Suggest that you start a new thread for the new question.In summary, the conversation discusses how to convert an intermediate value, 570 +/- 100, into its final form. The uncertainty in the value is questioned, with some suggesting it should be 600 +/- 100 while others argue for 570 +/- 5. The possibility of having units in exponents is also briefly discussed. The conversation also touches on the difference between uncertainties and significant digits, and why some quantities are considered vectors while others are not. It is suggested to start a new thread for this new question.
MathewsMD
433
When dealing with the intermediate value of example: 570 +/- 100, how do you put this into it's final form? If I'm not mistaken, doesn't the uncertainty only contain 1 significant digit? Doesn't the uncertainty digit have to correspond to the final significant digit on the actual value as well? In that case, is the final answer 600 +/- 100 or is it appropriate to leave as 570 +/- 100 as the final answer?
Mathematics news on Phys.org
It seems to me that there is some dissonance between 570 (with two sig. digits) and the uncertainty 100 (with one sig. digit). I would go with 600 ##\pm## 100 - that makes more sense to me.
Something more reasonable would be 570 ##\pm## 5. This suggests that there is uncertainty in the tens place (7 digit), but having 570 ##\pm## 100 suggests uncertainty in the hundreds place (5 digit), which makes the 7 digit worthless.
That's what I was thinking too...i went with 600 and got the mark wrong.
Also, what happens if you have units in the exponent? Just curious, is it possible?
Yes/no?
Was this a computer-scored problem or one that was graded by a person? If the latter, I would talk to this person and find out why that answer was considered incorrect.
I don't believe you can have units in the exponent. Any units would have to cancel, leaving an exponent with no units. If I'm wrong in this, please show me an example where things are otherwise.
Yep. I actually spoke with the lab coordinator and the explanation I received went along the lines of "You have 570 +/- 100 in the intermediate value, and this shows more precision than 600 +/- 100." Maybe I misinterpreted him, but it didn't really make sense to me since an extra digit is carried in the calculations. I honestly don't care that much about the mark but maybe I'll ask again for another explanation. Although unnecessary marks off aren't fair, I rather just know this for my personal knowledge. I may have done an erroneous calculation and not canceled units properly, but I'll try to find the example I was working on a while ago and post it if I find it. As long as there is no method to actually consider units in exponents in ordinary equations, that should be helpful enough since units most likely do cancel in the aforementioned problem.
My last question is: why are some quantities vectors while others aren't? For example, we can calculate both current and current density, but why do we only consider current density to be a vector and current a scalar quantity? Is it a purely arbitrary convention or is it something more mathematically fundamental? I understand vectors like forces and displacement have directions and magnitudes associated with them, but I don't quite understand why we don't do the same thing for quantities like current? Is it to simplify equations only?
Don't mix uncertainties and significant digits.
570 +/- 100 is a statement that the actual value lies between 470 and 670 with a certain probability. 600 +/- 100 is a statement that the actual value lies between 500 and 700 with the same probability, and that's a different thing.
It made sense to use significant digits in intermediate values back when people used slide rules for intermediate calculations, so the method of computation itself introduced uncertainties that were directly related to the digit position. But that was then.
MathewsMD said:
My last question is: why are some quantities vectors while others aren't? For example, we can calculate both current and current density...
Hmm..okay so do you mind expanding on which of the two expressions would be more accurate?
Related to Uncertainty significant digits
1. What is the definition of uncertainty in significant digits?
Uncertainty in significant digits refers to the amount of error or imprecision in a measurement or calculation. It is typically expressed as the number of digits that are uncertain or estimated in a given value.
2. How is uncertainty in significant digits calculated?
The uncertainty in significant digits is calculated by determining the precision of the measuring instrument or calculation and then counting the number of digits that are certain and uncertain. The last digit of the uncertain value is rounded up or down depending on the value of the following digit.
3. Why is it important to consider uncertainty in significant digits?
It is important to consider uncertainty in significant digits because it provides a measure of the accuracy and reliability of a measurement or calculation. It allows scientists to determine the level of confidence in their results and communicate the potential margin of error to others.
4. How does uncertainty in significant digits affect scientific experiments?
Uncertainty in significant digits can affect scientific experiments by introducing error or imprecision into the data. This can impact the validity and reliability of the results, as well as the ability to draw accurate conclusions.
5. What are some common sources of uncertainty in significant digits?
Common sources of uncertainty in significant digits include limitations of measuring instruments, human error in making measurements, and rounding in calculations. Environmental factors, such as temperature and humidity, can also contribute to uncertainty in significant digits.
  • General Math
  • Other Physics Topics
