Uncovering Overlooked Solutions: Solving a Triple Integer Equation
  • MHB
  • Thread starter anemone
In summary, the conversation discusses finding all triplets of positive integers that satisfy a given equation. The GM-AM inequality is used to narrow down the possibilities and it is determined that the only possible values for one of the variables is 1. After substitution, it is found that the only possible values for the remaining variables are 1 and 2, giving two possible solutions for the original equation. The speaker also mentions a lesson learned about checking all possibilities.
anemone
MHB
POTW Director
3,883
115
Find all triples $(a,\,b,\,c)$ of positive integers such that $\dfrac{a}{b}+\dfrac{b}{c+1}+\dfrac{c}{a}=\dfrac{5}{2}$.
Mathematics news on Phys.org
[sp]By the GM-AM inequality, $\Bigl(\dfrac{abc}{b(c+1)a}\Bigr)^{1/3} \leqslant \dfrac13\Bigl(\dfrac ab + \dfrac b{c+1} + \dfrac ca\Bigr) = \dfrac56.$
Therefore $\dfrac{abc}{b(c+1)a} \leqslant \Bigl(\dfrac56\Bigr)^3$. Taking reciprocals, $1 + \dfrac1c \geqslant \Bigl(\dfrac65\Bigr)^3 = 1.728.$ The only way that can happen for a positive integer $c$ is if $c=1.$
Putting $c=1$, the original equation becomes $\dfrac ab + \dfrac b2 + \dfrac1a= \dfrac52.$ Multiplying out the fractions, that becomes $2a^2 - b(5-b)a + 2b = 0$, a quadratic in $a$ with solution $a = \frac14\bigl(b(5-b) \pm\sqrt{b^2(5-b)^2 - 16 b}\bigr).$ For this to give a positive value for $a$ we must clearly have $b<5$. But $b=3$ and $b=4$ make that square root negative, so the only possible values for $b$ are $b=1$ and $b=2.$ It is easy to check that those both give solutions, with $a=b$ in both cases.
Therefore the solutions are $(a,b,c) = (1,1,1)$ and $(a,b,c) = (2,2,1)$.[/sp]
Thanks for participating, Opalg!:)
Solution of other:
We can rewrite the given equation to get:
$\dfrac{a}{b}+\dfrac{b}{c+1}+\dfrac{c+1-1}{a}=\dfrac{5}{2}$
$\dfrac{a}{b}+\dfrac{b}{c+1}+\dfrac{c+1}{a}-\dfrac{1}{a}=\dfrac{5}{2}$
$\dfrac{a}{b}+\dfrac{b}{c+1}+\dfrac{c+1}{a}=\dfrac{5}{2}+\dfrac{1}{a}$
Applying AM-GM inequality to the terms on the left, we have:
$\begin{align*}\dfrac{a}{b}+\dfrac{b}{c+1}+\dfrac{c}{a}&\ge 3\sqrt[3]{\dfrac{a}{b}\cdot \dfrac{b}{c+1}\cdot \dfrac{c+1}{a}}\\&\ge 3 \end{align*}$
This implies $\dfrac{1}{a}\ge \dfrac{1}{2}$, which means $a\le 2$.
We thus have to consider two cases, $a=2$ and $a=1$.
When $a=2$, equality must be attained, i.e. $\dfrac{2}{b}=\dfrac{b}{c+1}=\dfrac{c+1}{2}$.
It follows that $b(c+1)=4$ so we have two choices, $b=2$, $c=1$ or $b=1$, $c=3$.
However, note that the second pair of solution does not satisfy $\dfrac{2}{b}=\dfrac{b}{c+1}$, thus we get only one solution in this case, namely $(a,\,b,\,c)=(2,\,2,\,1)$.
If $a=1$, the equality becomes $\dfrac{1}{b}+\dfrac{b}{c+1}+c=\dfrac{5}{2}$, which implies $c<2$.
For $c=1$, we get $\dfrac{1}{b}+\dfrac{b}{2}=\dfrac{3}{2}$, i.e. $b^2-3b+2=0$. This gives two solutions, $b=1$ and $b=2$ that yield $(a,\,b,\,c)=(1,\,1,\,1),\,(1,\,2,\,1)$.
For $c=2$, we get $\dfrac{1}{b}+\dfrac{b}{3}=\dfrac{1}{2}$, i.e. $2b^2-3b+6=0$. This does not have positive integer solutions.
We conclude that all solutions are given by that yield $(a,\,b,\,c)=(1,\,1,\,1),\,(1,\,2,\,1),\,(2,\,2,\,1)$.
Opalg has overlooked the pair $(a,\,b,\,c)=(1,\,2,\,1)$ but I know that is purely an honest careless mistake.(Smile)
[sp]Notice that the solution that I overlooked was in the section where I casually claimed "It is easy to check ...". Therein lies a lesson. (Shake)[/sp]
FAQ: Uncovering Overlooked Solutions: Solving a Triple Integer Equation
What is the purpose of finding all triples (a, b, c)?
The purpose of finding all triples (a, b, c) is to solve mathematical problems or equations that involve three unknown variables. By finding all possible combinations of the variables, we can determine the solutions to the problem or equation.
How do you find all triples (a, b, c)?
To find all triples (a, b, c), we can use a systematic approach such as trial and error or algebraic manipulation. We can also use computer algorithms or programming to generate all possible combinations of the variables.
What are some applications of finding all triples (a, b, c)?
Finding all triples (a, b, c) can be used in various fields such as cryptography, statistics, and genetics. It can also be applied in solving real-world problems such as optimizing resource allocation, predicting market trends, and analyzing data sets.
Are there any limitations to finding all triples (a, b, c)?
There may be limitations to finding all triples (a, b, c) depending on the complexity of the problem or equation. In some cases, it may be impossible to find all possible solutions due to computational constraints or lack of information.
Can finding all triples (a, b, c) be generalized to more than three variables?
Yes, finding all triples (a, b, c) can be generalized to any number of variables. However, as the number of variables increases, the complexity of finding all possible combinations also increases, making it more challenging to find all solutions.
