Uncovering the Mystery of Work Done by Conservative Forces
In summary, the conversation discusses the equation for work done by conservative forces and its application in a situation with no potential energy changes but still with work done by friction. The conclusion is that friction is a non-conservative force and does not contribute to the change in potential energy. Therefore, in this scenario, the work done by conservative forces is equal to the work done by non-conservative forces, which is 0J. There are no conservative forces acting in this situation.
ikjadoon
37
Work done by conservative forces = -[tex]\Delta[/tex]U
Above.
Here is the whole equation:
Wc+ Wnc = [tex]\Delta[/tex]K.
Wnc = [tex]\Delta[/tex]K + [tex]\Delta[/tex]U.
So, Wc = -[tex]\Delta[/tex]U.
But, for example, how does that apply in a situation with no potential energy changes, but still with work done by conservative forces?!
Example: a block slides across a horizontal, flat table and comes to rest due to friction. There was no change in gravitational or spring-related potential energy (the only two forms of potential energy I can think of). However, there was work done (50J or whatever) by friction on the block. Thus, 50J = 0J! There is no change in potential energy, but there was work done by conservative forces.
Where did I go wrong?
Thanks,
~Ibrahim~
Why did you assume that friction was a conservative force? either one of your first 2 equations would be OK to use. The third one says that since there was no potential energy change, there was no work done by conservative forces (no work done by gravity, springs, or other conservative forces).
Oh, crap.
Friction is a non-conservative force: it depends on the path.
There are no conservative forces acting, only non-conservative (friction).
0J = 0J.
Got it. Thanks for the solution, however simple!
~Ibrahim~
Related to Uncovering the Mystery of Work Done by Conservative Forces
1. What is the definition of conservative forces?
Conservative forces are forces that are independent of the path taken by an object and only depend on its starting and ending positions. This means that the work done by a conservative force is the same regardless of the path taken, as long as the starting and ending points remain the same.
2. How do conservative forces differ from non-conservative forces?
Unlike conservative forces, non-conservative forces are path-dependent and the work done by these forces is not only determined by the starting and ending positions, but also by the path taken. Examples of non-conservative forces include friction, air resistance, and tension in a rope.
3. What is the formula for calculating the work done by conservative forces?
The work done by conservative forces is calculated using the formula W = -ΔU, where W is the work done, ΔU is the change in potential energy, and the negative sign indicates that the work done is in the opposite direction of the change in potential energy.
4. How can we determine if a force is conservative or non-conservative?
A force is considered conservative if the work done by the force is the same for all possible paths between two points. This can be determined by calculating the work done along different paths and comparing the results. If the work done is the same, the force is conservative. If the work done is different, the force is non-conservative.
5. What are some real-life examples of conservative forces?
Some common examples of conservative forces include gravity, elastic forces (such as those in a spring), and electrostatic forces. These forces are considered conservative because the work done by them is independent of the path taken by an object and only depends on its initial and final positions.
