Understading geodesic equation/code for (+1,-1,-1,-1) Sch. Metric
In summary, please make sure to check and define the following variables correctly: "M", "eta", "L_aux", "E_aux", and "M_aux" in order to produce the desired results.
Arman777
Insights Author
193
Hey guys, as you may remember, I have posted a question about plotting the orbit of timelike and null-like particles for a given metric.
I think this discussion might be helpful for me and some other people in future studies. I have found an article, and in that article, the authors are using Sagemath to run the code. Luckily to run the Sagemath, you can use an online editor called CoCalc (https://cocalc.com/).
To run a Sagemath code, open a notebook and choose kernel as SageMath 9.3
Here is the code given by the authors.
Code:
reset()
# Define 4-dim. the manifold "Man":
Man = Manifold(4, 'Man', r'\mathcal{M}')
# Define the parameter "M" (mass):
M = var('M')
# Define the coordinates {t=0, r=1, theta(=th)=2, phi=3} with ranges
# (BL = Boyer-Lidquist)
BL.<t,r,th,ph> = Man.chart(r't r:(0,+oo) th:(0,pi):\theta ph:(0,2*pi):\phi')
# Define the metric "g" on manifold "Man":
g = Man.lorentzian_metric('g')
# Enter the Schwarzschild metric components:
g[0,0] = (1-(2*M)/r)
g[1,1] = -1/(1-(2*M)/r)
g[2,2] = -r^2
g[3,3] = -(r*sin(th))^2
# Display the metric
show('The Schwarzschild metric:')
show(g.display())
# Define variables, functions and calculate inverse metric
var('eta,m,E,L,S,HJfull')
F=function('F')(r)
G=function('G')(th)
ginv = g.inverse()
# Define the principal function Ansatz
S=((eta*m^2)/2)-E*t+L*ph+F+G
# Calculate the Hamilton-Jacobi equation
HJfull=0
for i in range(len(BL[:])):
    for j in range(len(BL[:])):
        HJfull=HJfull+ginv[i,j].expr()*diff(S,BL[i])*diff(S,BL[j])
HJfull=(diff(S,eta)-(1/2)*HJfull)
show('The Full Hamilton-Jacobi equation (variable name is HJfull):')
show(HJfull)
show('The geodesic equations in LaTeX form (variable name is geodeqnrhs):')
geodeqnrhs=zero_vector(SR, len(BL[:]))
for mu in range(len(BL[:])):
    for nu in range(len(BL[:])):
        geodeqnrhs[mu]=geodeqnrhs[mu]-(ginv[mu,nu].expr())*diff(S,BL[nu])
    writeresult='D[0](%s)($\eta$) = $%s$' %(BL[mu],latex(geodeqnrhs[mu]))
    show(writeresult)
show('Right hand sides of the geodesic equations as a vector')
show(geodeqnrhs)
# Take theta = pi/2:
var('HJst')
# Hamilton-Jacobi equation for theta=pi/2 (variable name is HJst)
HJst=(HJfull.subs(diff(G)==0)).subs(th=pi/2)
show(HJst)
# Right hand sides of the geodesic equations for theta=pi/2
# (variable name is geodeqnrhsst)
geodeqnrhsst=(geodeqnrhs.subs(diff(G)==0)).subs(th=pi/2)
show(geodeqnrhsst)
# Importing the solver
from sage.calculus.desolvers import desolve_odeint
#Importing circle for visualizing the black hole
from sage.plot.circle import Circle
var('m_aux,L_aux,E_aux,M_aux,r_initial,ph_initial,eta_end,step_size')
# Variables
m_aux=1 # Either 1 (timelike) or 0 (null).
M_aux=1
L_aux=4
E_aux=1.0
step_size=0.1
eta_end=500
r_initial=2.1*M_aux
ph_initial=0.3
# Derivative of F (the radial function)
# (variable name is derofradfun)
# We will use the first root
derofradfun=solve(HJst,diff(F,r))
# Define equations to solve
# dr/dt = geodeqn1
# dphi/dt = geodeqn2
geodeqn1=((geodeqnrhsst[1]/geodeqnrhsst[0]).subs(diff(F,r)==derofradfun[1].rhs())).subs(E=E_aux,L=L_aux,m=m_aux,M=M_aux)
geodeqn2=(geodeqnrhsst[3]/geodeqnrhsst[0]).subs(E=E_aux,L=L_aux,m=m_aux,M=M_aux)
# Solve the equations
sol=desolve_odeint([geodeqn1,geodeqn2],[r_initial,ph_initial],srange(0,eta_end,step_size),[r,ph])
p=line(zip(sol[:,0]*cos(sol[:,1]),sol[:,0]*sin(sol[:,1])))
# Plot the black hole as a circle
# Show the geodesics and the circle on the same plot
C=circle((0,0),2*M_aux,fill=True,rgbcolor='black')
show(C+p)
If you be careful, you'll see that the metric defined as ##diag(1,-1,-1,-1)##, and the variables are given in lines 75-85. I have tried to plot the images that I have provided in this post (https://www.physicsforums.com/threa...ulate-orbits-in-schwarzschild-metric.1003484/)
but for some reason, I could not produce the pictures.
In the code given above the ##L_{aux}## (the angular momentum) is given by ##4## but in my code it will be ##L_{aux} = 4.3##.
So the problem is, when I change the energy levels to see how the code/program reacts, I am getting either strange results and sometimes errors. Do you guys have an idea how can make the code work to produce those images?
In general in many books the metric is given by ##diag(-1,1,1,1)##. When you change the metric in lines ##16-23##, you guys should also change the equation in ##33## (I guess).
Here is the article: https://arxiv.org/abs/1703.09738
Look Section 4.3 in page 15
Thanks
Likes yucheng and (deleted member)
for sharing the code and the article. It seems like you are trying to plot the geodesics of particles in the Schwarzschild spacetime. The code you have shared looks correct, and it is using the Schwarzschild metric in the Boyer-Lindquist coordinates. However, I noticed a few things that might be causing issues with your results.
Firstly, in line 35, the variable "M" is not defined. It should be defined as the parameter "M" which represents the mass of the black hole. Also, in line 36, the variable "eta" is not defined. It should be defined as the affine parameter along the geodesic.
Secondly, in line 84, the variable "L_aux" is defined as 4.3, but in the article, it is mentioned as 4. It is possible that this discrepancy is causing issues with your results.
Thirdly, in line 87, the variable "E_aux" is defined as 1.0, but in the article, it is mentioned as 1. It is possible that this discrepancy is also causing issues with your results.
Lastly, in line 98, the variable "M_aux" is defined as 1, but in the article, it is mentioned as 1.5. It is possible that this discrepancy is also causing issues with your results.
I would suggest checking these variables and values to see if they match with the ones mentioned in the article. Also, make sure to define all the necessary variables before running the code. If you are still having issues, please provide more details about the errors or strange results you are getting. I would be happy to help further.
FAQ: Understading geodesic equation/code for (+1,-1,-1,-1) Sch. Metric
What is a geodesic equation/code?
A geodesic equation/code is a mathematical formula that describes the shortest path between two points on a curved surface, such as a sphere or a curved spacetime. It takes into account the curvature of the surface and the initial conditions of the path to determine the geodesic, which is the path of least resistance.
What does the (+1,-1,-1,-1) Sch. Metric represent?
The (+1,-1,-1,-1) Sch. Metric, also known as the Minkowski metric, is a mathematical representation of the spacetime interval in special relativity. It is used to calculate the distance between two events in spacetime and takes into account the differences in the time and space components of the interval.
How is the geodesic equation/code related to the Sch. Metric?
The geodesic equation/code is used to calculate the shortest path between two points on a curved surface, while the Sch. Metric is used to calculate the distance between two events in spacetime. The geodesic equation/code takes into account the curvature of the surface, which is determined by the Sch. Metric.
Why is understanding the geodesic equation/code for the (+1,-1,-1,-1) Sch. Metric important?
Understanding the geodesic equation/code for the (+1,-1,-1,-1) Sch. Metric is important for understanding the fundamental principles of special relativity and how objects move in curved spacetime. It also has practical applications in fields such as physics and astronomy, where the concept of geodesics is used to describe the motion of particles and light.
Are there any real-world examples of the geodesic equation/code for the (+1,-1,-1,-1) Sch. Metric?
Yes, there are many real-world examples of the geodesic equation/code for the (+1,-1,-1,-1) Sch. Metric. One example is the motion of planets around the sun, which can be described using geodesics in spacetime. Another example is the path of light around a massive object, such as a black hole, which is also determined by the geodesic equation/code.
