Understanding a book example about centripetal force
In summary, the centripetal force is the radial component of the resultant force which is the vector sum of ##\vec{n}_{bot ~or ~top} +m\vec{g}##. It points in the same direction as the centripetal acceleration and is always positive. If you switch to a non-inertial view and replace the centripetal force with a centrifugal one, the acceleration on the left side of the equation will be negative.
Bunny-chan
105
If the centripetal force is at the left side of the equation; that means if we move it over to the other side, it'll have a negative sign, which means it is opposite in sense in relation to [itex]N[/itex] and [itex]mg[/itex]. But how is that possible, considering that the centripetal force always points to the center of the circumference?
The centripetal force is the force that provides the centripetal acceleration. In this case, it is the vector sum of ##\vec{n}_{bot ~or ~top} +m\vec{g}##. Note that it points in the same direction as the centripetal acceleration in both diagrams which is all that is required of it.
Likes FactChecker
Bunny-chan said:
opposite in sense in relation to N and mg. But how is that possible, considering that the centripetal force always points to the center of the circumference?
Centripetal force is not an applied force, like N and mg are. It is the radial component of the resultant force.
If you shift it to the other side and combine it with real applied forces as though it is another such then in effect you are switching to a non-inertial view, replacing the centripetal force with a centrifugal one. That acts away from the centre.
Since gravitational force is down and it has a positive sign, down is positive. The acceleration on the left side of the equation is downward when at the top of the loop, so it needs to be positive. The rest follows.
FactChecker said:
Are you sure this is centripetal force and not centrifugal force?
The first quoted equation has ΣFr=mv2/r, so I would say the book treats it as centripetal at that point. But see post #3.
Yes. Sorry. I was correcting my post as you responded to it..
OK. I understand it now. Thanks for the inputs.
Related to Understanding a book example about centripetal force
1. What is centripetal force?
Centripetal force is the force that acts on an object moving in a circular path, always directed towards the center of the circle. It is responsible for keeping the object's motion in a circular path rather than moving in a straight line.
2. How is centripetal force related to understanding a book example?
In a book example about centripetal force, the concept of centripetal force is used to explain how objects in circular motion are affected by a force that pulls them towards the center of the circle. This helps readers understand the concept of centripetal force in a real-life scenario.
3. What are some common examples of centripetal force?
Some common examples of centripetal force include the force acting on a car as it turns a corner, the force keeping a satellite in orbit around the Earth, and the force exerted by a person's hand on a rope to keep a ball moving in a circular motion.
4. How is centripetal force different from centrifugal force?
Centripetal force and centrifugal force are often misunderstood to be the same, but they are actually opposite forces. Centripetal force pulls an object towards the center of the circle, while centrifugal force is the outward force that an object experiences as a result of its circular motion.
5. What are the practical applications of understanding centripetal force?
Understanding centripetal force is important in various fields of science and engineering. It is used in designing roller coasters, analyzing the motion of planets and satellites, and studying the dynamics of vehicles in motion. It also has practical applications in everyday life, such as in the functioning of washing machines and amusement park rides.
