Understanding a dendrogram (no cursework)
  • Thread starter hexa
In summary, the individual is seeking help in understanding a provided diagram from their workplace. The diagram features four different groups or colors, with a black dot representing each group. The individual is unsure about the boundaries between the groups and how to interpret the diagram overall. They also mention that the diagram is meaningless without context.
hexa
34
Hello,
I tried to find a fitting forum but did not quiet succeed. The following diagram is an example of something I've been given at work. I try to understand it but fail with that.
http://img98.imageshack.us/img98/4770/testwk3.png
So how do I understand such diagram? The upper black dot comprises all the data in all 4 groups or colours, the second highest black dot assumes two groups? But where's the boundary then: between the light blue and green? What are the boundaries of the third black dot? Basically: how do I understand such diagram?
Thanks a lot,
H.
The Dendogram is meaningless without some context.
(Whew! I'm glad I got through that without cursing...)
Hello H.,
Thank you for reaching out and sharing your confusion about the dendrogram. A dendrogram is a type of hierarchical clustering diagram that is commonly used to visualize relationships between groups or data points. In this diagram, the vertical axis represents the measure of similarity or distance between the different groups or data points, while the horizontal axis represents the different groups or data points themselves.
In this specific diagram, it looks like the data points are being clustered into four distinct groups or categories, represented by the different colors. The black dots at the top of the diagram represent the overall groupings of the data, with the first black dot encompassing all four groups and the second black dot representing a split between two groups. The boundaries between the groups are shown by the horizontal lines connecting the different colored data points.
The third black dot represents a further split within one of the groups, with the boundary between the light blue and green groups being shown by the horizontal line connecting those two data points. The boundaries of the third black dot are determined by the measure of distance or similarity between the data points within that group.
Overall, the dendrogram is showing the relationships and groupings between the data points, with the distance or similarity between them being used to determine the boundaries between the different clusters. I hope this helps clarify the diagram for you. If you have any further questions, please don't hesitate to ask.
FAQ: Understanding a dendrogram (no cursework)
What is a dendrogram?
A dendrogram is a type of diagram used to represent hierarchical relationships between data points. It is commonly used in clustering analysis to show how different data points are grouped together based on their similarities.
How is a dendrogram interpreted?
A dendrogram is interpreted by observing the length of the branches and the order of the data points. The length of the branches represents the level of similarity between data points, with shorter branches indicating a higher level of similarity. The order of the data points on the x-axis shows the relative distance between them.
What are the different types of dendrograms?
There are two main types of dendrograms: agglomerative and divisive. Agglomerative dendrograms start with individual data points and merge them together based on their similarities, while divisive dendrograms start with all data points together and then split them into smaller groups based on their differences.
What is the purpose of using a dendrogram?
The purpose of using a dendrogram is to gain insight into the relationships between data points and identify patterns or clusters within the data. It can also help in decision-making processes, such as identifying groups of customers with similar characteristics for targeted marketing strategies.
How does one create a dendrogram?
To create a dendrogram, one must first have a set of data points and a measure of similarity or dissimilarity between them. This data is then input into a hierarchical clustering algorithm, which will generate the dendrogram. The dendrogram can then be visualized using various software or programming languages.
